@Robert_Muller I’ve deleted the code you posted, because it was totally unreadable.
When you post code it needs to have triple backticks at the beginning and end. Triple backticks look like this.
It also needs to have regular line breaks (carriage returns, line feeds) at the end of each line, so that it is readable.
I’d also suggest that you re-read the information below, which is what we ask you to do when you create a new topic on the forum, and provide the missing information…
Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
