Mine is not as complex, theres no video feed and I’m using a simple DC motor not a stepper.
The problem: I have a command to the motor telling it to activate. Then theres a setTimeout calling a command for it to stop. The function the motor command is in IS being called as I the serial.prints are coming through. If I take the motor on instruction and put it in void loop, it works.
I know the varTimer = pinValue is probably wrong but it was a way of taking the integer from one virtual pin and using it another function. The idea being the slider will define the timeout period.
http://twitter.com/blynk_app
This sketch shows how to read values from Virtual Pins
App project setup:
Slider widget (0...100) on Virtual Pin V1
#include "WEMOS_Motor.h"
char auth[] = "token";
char ssid[] = "ssid";
char pass[] = "password";
int varTimer;
Motor M1(0x30,_MOTOR_A, 1000);//Motor A
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V1)
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
varTimer = pinValue;
BLYNK_WRITE(V3)
if(param.asInt() == 0) {
FeedStart();
void FeedStart() // Rotate the rotor
M1.setmotor( _CW, 100);
Serial.print(" FEEDING ");
Serial.print(" for ");
Serial.println(varTimer);
timer.setTimeout(5000, FeedStop); //After 5 seconds call the FeedStop function
void FeedStop() // stop the rotor
M1.setmotor(_STANDBY);
Serial.println("END OF FEEDING ");
Yes its the wemos motor shield stacked on top of a D1 so all the headers are populated. Its a 12v motor connected to A1 and A2
V3 is a button in push mode. V3 gets updated on press and again on release so yes, when it goes back to 0 then FeedStart is called - which appears to be the case, I am getting the “FEEDING” message and the “END OF FEEDING” message 5 seconds later.
If I change V3 to a switch it calls FeedStart on the second press, which is consistent. The motor does not activate on either press.
Change the button to switch and the V3 if statement to == 1 just as a test.
Do you know what the 100 does in setMotor()? 100ms / 100 degrees etc.
If it’s 100ms then it would work in loop() as it keeps repeating but you probably wouldn’t notice a single 100ms movement from pressing V3.
Going back the the project I’m basing mine off - If I change the ode to the following it works as it should. Which is ok but it’d be better to know why it doesn’t work the other way…
// get the man switch value
if (digitalRead(V3) > 0) // feeds and updates the hopper level/man trigger count on manual trigger
FeedStart();
I think it’s because you haven’t declared the timeout correctly but I would be more interested in starting the motor in the first place than stopping it.
For slider operation all you need to do is define a global variable:
int feedSeconds = 5;
BLYNK_WRITE(V1)
feedSeconds = param.asInt(); // assigning incoming value from pin V1 to a variable
Serial.println(feedSeconds);
timer.setTimeout(feedSeconds * 1000, FeedStop); //Slider set feeding time in ms
Not sure why V3 is not starting the motor but I would change it to normal logic of switch and 1 rather than push and 0.
