I’m trying to use blynk app to trigger a python script on Raspberry Pi 4 which toggles a fan or light. I can’t get it to work. When I run the app on the Pi and clink on button1 on my phone I get “Got a value : 4”. But when I click button2, the VirtualPin2 value is not shown. Also the actual python script isn’t run either. My main.cpp looks like this:
#define BLYNK_PRINT stdout
#ifdef RASPBERRY
#include <BlynkApiWiringPi.h>
#else
#include <BlynkApiLinux.h>
#endif
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
#include <BlynkWidgets.h>
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V1)
if (pinValue == 4 || pinValue == 0)
system("python3 /home/pi/Desktop/Automation/light_toggle.py");
// process received value
BLYNK_WRITE(V2)
if (pinValue == 5 || pinValue == 0)
system("python3 /home/pi/Desktop/Automation/fan_toggle.py");
int main(int argc, char* argv[])
const char *auth, *serv;
uint16_t port;
parse_options(argc, argv, auth, serv, port);
Blynk.begin(auth, serv, port);
setup();
while(true) {
loop();
return 0;
