Help with integrating Blynk code into sketch
I’m a bit of a blynk noob here, but here it goes…
I have built an electronic gate opener with an arduino and can open the gate via wireless keypad nicely. I have installed the blynk libraries and have been able to connect to the arduino to the blynk server.
My question is how do I incorporate my existing sketch into the GSM communication sketch? From what I have read I cannot place it in the void loop?
Any help is appreciated.
int gateOpen = 4;
int gateClose = 5;
int keypad = 12; //regular keypad
int exitOpener = 13; //exit sensor
  pinMode(gateOpen, OUTPUT);
  pinMode(gateClose, OUTPUT);
  pinMode(keypad, INPUT_PULLUP);
  pinMode(exitOpener, INPUT_PULLUP);
  if (digitalRead (keypad) == LOW || digitalRead (exitOpener) == LOW)
    digitalWrite(gateOpen, HIGH);
    delay(8000);
    digitalWrite(gateOpen, LOW);
    delay(10000);
    digitalWrite(gateClose, HIGH);
    delay(10000);
    digitalWrite(gateClose, LOW);
Would something like this work?
// Select your modem:
#define TINY_GSM_MODEM_SIM800
//#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
char auth[] = "authcode";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[]  = "hologram";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
int gateOpen = 4;
int gateClose = 5;
  // Set GSM module baud rate
  SerialAT.begin(115200);
  delay(3000);
  modem.restart();
  // Unlock your SIM card with a PIN
  //modem.simUnlock("1234");
    delay(8000);
    delay(10000);
    delay(10000);
