You are wrong ;). You can send any number you want. For example, I use it to address a PWM dimmable LED. In theory I could add a webhook to send the number I’m speaking.
Have you tried sending [“0”] or [“1”] instead of toggle? Because I don’t see anything in your code to reflect that. Besides, a digital pin can only be 1 or 0.
Write a Blynk function that is called whenever your voice command happens… the function will simply toggle the relays current pin state to its opposing state.
BLYNK_WRITE(Vx) { // Relay toggle function processes the following command regardless of the state of the calling vPin
digitalWrite(RelayGPIOpin, !digitalRead(RelayGPIOpin)); // Go HIGH if LOW, go LOW if HIGH
You may want to add in some minor timer and flag to keep this from rapidly flip flopping if this function somehow gets rapidly called (e.g. as would happen if using a momentary Button Widget to call this function).
You could also make it so that your voice command always triggers a HIGH, and make this function only trigger on HIGH, but then after flipping the relay, reset the vPin to LOW.
ive tried to learn more about the project which i put on the back burner and have gotten to here
my understanding is that i will call for a virtual pin via iftt to high or “1” then the code will take that and decide what the state of the pin is and change it accordingly ?
here is the code i have attempted (which doesnt work )
char auth[] = "xxxxxxxxxxx";
char ssid[] = "xxxxxxxh";
char pass[] = "xxxxx";
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 84xx);
//Blynk.begin(auth, ssid, pass, IPAddress(192,1xx,1,100), 84xx42);
int outputPin = 14;
BLYNK_WRITE(V1) ; // Relay toggle function processes the following command regardless of the state of the calling vPin
digitalWrite(outputPin, !digitalRead(outputPin)); // Go HIGH if LOW, go LOW if HIGH
so my understanding of what you have written ( as im a complete noob) is
blynk_write(vx) is the virtual pin my iftt will call for
i will need to assign a gpio pin and define it as (Relay GPIOpin)
after looking around i have found other people doing similar thing to what i am trying to achieve but using current/voltage sensing, that is a option but not required as i can use a voice command to just change the state of a two position relay using the voice command “hallway lights”
i am basically creating a three way switch with the "intermediate switch " being under the control of the google assistant and the node mcu
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
NOTE:
BlynkTimer provides SimpleTimer functionality:
http://playground.arduino.cc/Code/SimpleTimer
App project setup:
Value Display widget attached to Virtual Pin V5
char auth[] = "xxxxxx";
char ssid[] = "txxxdxxxxxixxx";
void myTimerEvent()
digitalWrite(14, !digitalRead(14)); // Using GPIO14 (D5) Go HIGH if LOW, go LOW if HIGH
