Changed, same problem
The timer.setInterval should turn to some color? I saw in some codes it was blue, in my code it stays gray. Did I call it in a wrong way?
In my IDE there is no special colouring for timer.setInterval().
I put some serial.print before the blynk.begin, it works. Same for HIGHing or LOWing pins. After Blynk.begin nothing independent from blynk works, I came to this conclusion.
Probably because Bluetooth is beta. Search the site for other BT users and see what hardware / sketches they are using. Iām still waiting for a BT module to arrive so I canāt help further.
flakey, wobbly, not perfect.
@Mateus_Henrique_da_S, if you are beginner in coding / blynking, stay away from bt / ble modules, otherwise you will loose your hair / go mad / rip your clothes / etc. very soonā¦
my advice is, for the beginning, buy an original wemos d1 mini pro from here
and by āhereā i do not mean ali, i mean exactly that link: the original wemos store.
Well that explains everythingā¦ now where did I put my pants?
Well, thanks I guess
If you havenāt alreadyā¦ search this site for Bluetooth, BLE, BT, etcā¦ there have been a few general explanations on how to get it working (as best as it can).
Some of the things to check:
- Correct BAUD rate for your module and sketch
- BT or BLE widget loaded in App and paired to your module.
- Confirm there are no restrictions in your phone for BT/BLE access from Blynk
- Phone still needs access internet to Cloud Server for Project login
- Do NOT attempt to send any serial data over the same port as the module is configured for, it will disrupt the link.
