Help with bridge code
First of all say that I’m pretty new with coding so bare with me :confounded:
I’m starting a new project and I need communication between two Arduino Uno boards. I followed all the examples and tutorials and came with this code. I’m not sure if it makes any sense or if it could be improved, any recommendation/suggestion will be much appreciated.
Want to make sure I’m moving the right direction before going any further.
The idea is to have a fsr connected to Arduino A and whenever the reading of the fsr is > 300 trigger a led to go HIGH on the Arduino B.
Code Arduino A (Sender):
const int led = 13;
int fsrPin = 0;
int fsrReading;
WidgetBridge bridge1(V1);
BLYNK_CONNECTED()
  bridge1.setAuthToken("OtherAuthToken");
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
  fsrReading = analogRead(fsrPin);
  bridge1.virtualWrite(V5, fsrReading);
  if (fsrReading <= 300) {
    bridge1.digitalWrite(led, LOW);
  if (fsrReading > 300) {
    bridge1.digitalWrite(led, HIGH);
Code Arduino B (Receiver):
const int led = 13;
int fsrPin = 0;
int fsrReading;
BLYNK_WRITE(V1)
  int pinData = param.asInt();
void loop(){
You may want to look at the bridge example in the sketch builder. You need to clear out your loop() by using the Blynk Timer.
I advice you to use same auth for reciver and main unit and use different virtual pins. This is more reliable solution. I don’t advice bridge widget.
