Help with blynk slider to turn on/off digital pin
he i wont turn on/off digital pin 6 with slider ( when its of = pin6 off ; when i move the slider its turn on from value1 the pin to high ) its for multi ( relay on/off and dimmer with same slider)
wats e good code for it .
thanks
i now i most do it with virtual pin . i struccel with the arduino code . for button i now i dont now for slider.
example slider code:
BLYNK_WRITE(V2) // tray warning temp (LOW)  slider
  setTrayLowerTemp = param.asInt();
    setTrayLowerAlarmTemp = setTrayLowerTemp - 5; //sets alarm temp at 5 (or whatever) degrees lower than the warning temp
    readDS18BFunction(); //runs the tray temp function again
BLYNK_WRITE(V0)
  dimmerValue = param.asInt();
  if(dimmer > 1)
     digitalWrite(relayPin, HIGH);
     analogWrite(someAnalogPin, dimmerValue);
     digitalWrite(relayPin, LOW);
This will turn on the relay and set the dimmer level in one go. There are variations and maybe it can be written shorter, but this is more readable :slight_smile:
i gave on error ( ‘dimmerValue’ was not declared in this scope
it’s a variable name, you have to declare variables or at least type them, try it like so:
int dimmerValue = param.asInt()
if you want to use the variable locally change
to
int dimmerValue = param.asInt();
if you need the variable to be global keep:
and add the following after your libraries:
int dimmerValue;
thanks it works now
the realy works , now i test the dime and its not work i take pmw uitgang
So your relay works but your dimmer doesn’t, correct?
Paste a link to your dimmer and your current sketch.
its work now thanks
BLYNK_WRITE(6)
dimmerValue = param.asInt(); // assigning incoming value from pin V6 to a variable
dimmerValue = (255./1023.) * param.asInt();
if(dimmerValue < 1)
digitalWrite(6 , HIGH);
analogWrite(5, dimmerValue);
digitalWrite(6, LOW);
this work well
