Help with ads1115, lcd2004, nodemcu
#include <SimpleTimer.h> //Blynk
#include <Wire.h>
#include <Adafruit_ADS1015.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
char auth[] = “";
char ssid[] = "
char pass[] = "*;
bool isFirstConnect = true;
Adafruit_ADS1115 ads; /* Use this for the 16-bit version /
//Adafruit_ADS1015 ads; /
Use thi for the 12-bit version */
float Voltage0 = 0.0;
float Voltage1 = 0.0;
float Voltage2 = 0.0;
float Voltage3 = 0.0;
Blynk.begin(auth, ssid, pass, “192.168.1.243”, 8080);
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) { // try to connect to server for 10 seconds
if((millis() / 1000) > mytimeout + 8){ // try local server if not connected within 9 seconds
break;
timer.setInterval(350L, ReadANAlOGS);
timer.setInterval(30000L, reconnectBlynk); // check every 30s if still connected to server
// The ADC input range (or gain) can be changed via the following
// functions, but be careful never to exceed VDD +0.3V max, or to
// exceed the upper and lower limits if you adjust the input range!
// Setting these values incorrectly may destroy your ADC!
// ADS1015 ADS1115
// ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV 0.1875mV (default)
ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
// ads.setGain(GAIN_TWO); // 2x gain +/- 2.048V 1 bit = 1mV 0.0625mV
// ads.setGain(GAIN_FOUR); // 4x gain +/- 1.024V 1 bit = 0.5mV 0.03125mV
// ads.setGain(GAIN_EIGHT); // 8x gain +/- 0.512V 1 bit = 0.25mV 0.015625mV
// ads.setGain(GAIN_SIXTEEN); // 16x gain +/- 0.256V 1 bit = 0.125mV 0.0078125mV
ads.begin();
Wire.begin(D2, D1);
lcd.begin();
lcd.home();
lcd.print(“1)”);
lcd.print(Voltage0);
lcd.setCursor(0,1);
lcd.print(“2)”);
lcd.print(Voltage1);
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
Blynk.notify(“ADS1115 STARTING!!!”);
isFirstConnect = false;
void ReadANAlOGS()
int16_t adc0, adc1, adc2, adc3;
adc0 = ads.readADC_SingleEnded(0);
adc1 = ads.readADC_SingleEnded(1);
adc2 = ads.readADC_SingleEnded(2);
adc3 = ads.readADC_SingleEnded(3);
Voltage0 = (adc0 * 0.125)/1000;
Voltage1 = (adc1 * 0.125)/1000;
Voltage2 = (adc2 * 0.125)/1000;
Voltage3 = (adc3 * 0.125)/1000;
Serial.print("AIN0: "); Serial.println(Voltage0);
Serial.print("AIN1: "); Serial.println(Voltage1);
Serial.print("AIN2: "); Serial.println(Voltage2);
Serial.print("AIN3: “); Serial.println(Voltage3);
Serial.println(” ");
Blynk.virtualWrite(V0, Voltage0);
Blynk.virtualWrite(V1, Voltage1);
Blynk.virtualWrite(V2, Voltage2);
Blynk.virtualWrite(V3, Voltage3);
void reconnectBlynk() {
if (!Blynk.connected()) {
if(Blynk.connect()) {
BLYNK_LOG(“Reconnected”);
BLYNK_LOG(“Not reconnected”);
if (Blynk.connected()) {
You need to format your code so that it displays correctly…
Blynk%20-%20FTFC
It would also make sense to include some explanation of where you are with this project. Does this code work? If not then what issues are you experiencing?
That’s what happens when people post incorrectly formatted code. The forum replaces straight quotes with open/closing quotes and you get an ‘unexpected 223 character’ (or something similar) when you try to compile it.
The OPs original code will be fine (at least in this respect), it’s just when we try to copy the code and compile it that we get problems.
My bad.
Not at all, if the code was posted correctly it wouldn’t be an issue :wink:
