Help, superchart is not sending the csv document to my email
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
char auth[] = “SfzXYjdTP0to1lp2PjpcEtK1doeXoo48”;
char ssid[] = “mwifi”;
char pass[] = “miguel12e”;
int P1 = D1;
int P2 = D2;
int P3 = D3;
int P4 = D4;
pinMode(P1,OUTPUT);
pinMode(P2,OUTPUT);
pinMode(P3,OUTPUT);
pinMode(P4,OUTPUT);
@frey002 Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Im not able to edit the post, can you help i just nead to send the data to my email but when i select the export data to csv option, nothing happends
