Help reading virtual pins
Cant seem to read a virtual pin, what I am trying to do is have a slider determine if it will be automated or a turn on or turn off the led
#include <Blynk.h>
char auth[] = "my authtoken";
int knap = 1;
char ssid[] = "My Network";
char pass[] = "My Code";
int Lys = 0;
void loop(){
  Blynk.virtualWrite(V1, digitalRead(13));
  Blynk.virtualWrite(V2, digitalRead(1));
  Blynk.virtualWrite(V0, analogRead(A0));
  // Måske bliver analogread til digitalread
    int Lys = analogRead(A0);
         knap = Blynk.virtualRead(V1)
      if (knap  = 0){
        digitalWrite(13, LOW)
      if (knap = 1) {
        digitalWrite(13, HIGH)
      if (knap = 2) {
          if (Lys > 500){
              digitalWrite(13, HIGH);
          else{
              digitalWrite(13, LOW);
you’ll probably want to read a bit more on how structure blynk code.
Your code structure is wrong. E.g. you void loop() should look like this:
perhaps if you use a timer and over the air update this can become this:
  ArduinoOTA.handle();
but no more than that. Then the actions you need to take with blynk are created in separate functions. Have a look at the examples in the sketchbuilder
further sections you want to read up on are
BLYNK_WRITE and BLYNK_READ
