Help me I want to connect LED+NodeMCU+Blynk
I am a beginner of blynk, I want to control On-Off to the LED light by using NodeMCU and Blynk
Now my arduino is installed for NodeMCU board now, but I don’t have a code of it,
please show me the code and tell the process to connect it with blynk. I don’t know anything
My teacher want to see it from me very soon, please help me
Hi…
so this is very basic. NodeMCU and blynk? So you want use the ESP8266, right?
You need on the hardware-side:
  • a ESP8266 (obviously). A 01 is sufficient
  • a LED
  • a resistor (470 Ohm should work)
  • a FTDI or an arduino (for uploading the script to the ESP)
  • some wifi-connection
On the software-side:
  • Arduino App
  • ESP Board add-on install as decribed here in the very first paragraph (i.e. “Installing with boards manager”)
  • Blynk library installed (download as ZIP and install from within arduino and added via ->sketch->include library->ZIP). Afterwards restart arduino
  • Blynk app of course
After that it’s easy going.
  • you solder the resistor to the positive side of the LED.
  • in Arduino you take the basic example for the ESP standalone: File->example->blynk->boards’n’shields->ESP standalone.
  • you modify two parts of the example:
    a) auth token (you get one in the app upon creation of a new project, where you also have to define the ESP8266 as the board to work with).
    b) the wifi info (SSID as well as password)
  • You upload the code via the arduino app (remember to select right board type and com port)
  • connect the led with the resistor to GPIO2 on the plus side and to ground on minus, power cycle the ESP and let it load the new firmware
  • in Blynk you chose the new project, add a button, choose digital GP2 and make it a switch
  • run the project and… blynk.
:smile:
Oh !!
can’t believe it’s work now
Thank you very much Minc
I really appreciate your help :smiley:
Wow! Thanks for such a detailed step by step guide!
Can we hire you for writing tutorials? :slight_smile:
Very very Well Minc!
Now, we increase the difficulty
Can you tell us, how to use more than one ESP8266-01 in Blynk?
I´m asking the same question in the community, but may be you
have a different strategic
This is sooo cool! I had a long term goal of figuring this out, but I stumbled upon this when searching for something else. I followed your steps and it ‘just worked’. Thanks much!
