Help invalid token
Hello. I need help. I can not use voice commands by IFTTT and google assistant. as response from (https://blynkapi.docs.apiary.io/) : invalid token. while I respected everything and i used valid token from my email account.
Thank you for your help.
You need to use the IP address of your Blynk cloud server rather than blynk-cloud.com
Search for Geo DNS for more info.
thank for your answer
i do it but nothing
https://blynkapi.docs.apiary.io/#reference/0/write-pin-value-via-put/write-pin-value-via-put?console=1
Your syntax is wrong. There should be nothing in the body.
How did you get the IP address of 45.55.96.146?
I’ve just checked and your project is on the Frankfurt server, which has the IP address of 139.59.206.133
which is what you should be using in your IFTTT recipe.
I thank you for your availability. I will try with the new IP address you proposed to me.
the IP address 45.55.96.146 I got it by a ping from blynk-cloud.com
Thank you very much. it works very well. Thanks for your help.
a little concern:
I have to use widgets for the blynk project presentation for my end-of-course work but I lack energy packs to add other widgets. can you help me to add just 2000 so that I present the complete application please
