I have connected my project (Switch of a Light On/Off) with the ESP8266 Wifi Shield, but I am getting output as “WiFi shield not present” on the Serial Monitor. Please help. Code is as follows:
#include <WiFi.h>
#include <BlynkSimpleWifi.h>
char auth[] = "auth_code";
char ssid[] = "ssid";
char pass[] = "password";
I have Arduino UNO Board+ESP8266 Wifi Shield. I want to remote control LED connected on Digital pin number 7 using Blynk App over the Internet. I embedded the above code in Arduino UNO board, but LED is not working. I am not getting how to code for LED in this program. Moreover my Arduino UNO is not getting IP Address from the router also.
Please Help
I have gone through the code mentioned at the link, What all changes will come for Arduino UNO Board ?
http://twitter.com/blynk_app
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Uno board
example.
#include <ESP8266_Lib.h>
char pass[] = "YourPassword";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
// to avoid delay() function!
Start with reading the comments and making the appropriate changes…
//#define EspSerial Serial1
SoftwareSerial EspSerial(2, 3); // RX, TX (or use appropriate pins on the WiFi sheild if different)
But I would drop this to 9600 for SoftwareSerial
