Hello there i need help with my projec dht11 temperature reading but with a simpler library it works but when the gauges update they go to zero every time and it anoys me any ideas ?
Also gauges are in one second pull mode and pull from esp
BLYNK_READ(V1){Blynk.virtualWrite(V1,dht.getTemperature());}
BLYNK_READ(V2){Blynk.virtualWrite(V2,dht.getTemperature());}
dht.setup(15);
// to avoid delay() function!
Because you are polling sensor too fast. As @wanek suggested try to get one reading per 3 seconds. DHT sensor report no value or some garbled data between two fast polling incidents.
