Help for widget timerinput
hello i want to use the timeinput widget to set the days and times of the week to turn on a light. I don’t know how to use it. Someone has the sketch ready and I use ethernet shield. Thanks
Sketch Builder is always a goo place to start:
https://examples.blynk.cc/?board=Arduino%20Uno&shield=Ethernet%20Shield%20W5100&example=Widgets%2FTimeInput%2FAdvancedTimeInput
Hello everyone I am new to the forum and I am trying to make the time input widgets turn on and off a lamp and I am not able to do the code. I am using ethernet shield someone could help me and send the code.
#include <Ethernet.h>
char auth = “YourAuthToken”;
void setup ()
Serial.Begin (9600);
Blynk.begin (auth);
BLYNK_CONNECTED () {
int startAt = 5 * 60; // 00: 05
int stopAt = (60 + 5) * 60; // 01: 05
// timezone
// full list of supported timezones could be found here
//https://www.mkyong.com/java/java-display-list-of-timezone-with-gmt/
char tz = “Europe / Kiev”;
Blynk.virtualWrite (V1, startAt, stopAt, tz);
// you may also pass day
// char days = “1”; // Monday
//Blynk.virtualWrite(V1, startAt, stopAt, tz, days);
// or days
// char days = “1,2,3”; // Monday, Tuesday, Wednesday
void loop ()
Blynk.run ();
Blockquote
but when I set the time it already sets the value and nothing happens.
You would have something other than the example.
one more thing i live in brazil i am using rtc being that it is a plus time ue in brazil example: seeu put on a lamp at 18:00 it does not call because the server time is 1 hour more
@EduardoSantino please edit this post (using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
