Help for virtual led RESOLVED
I would like to help, someone could take a simple example on how to use the virtual LEDs, I tried many combinations but do not get results.
I tested the sketch of the documentation, but I do not understand how to change the example
for example, activating a digital pin and activates the virtual LED
thanks
Have ypu checked this example?
I tested it and it works but I could not use this reference to create the new sketch
Could you please be more specific? What is the reason? What hardware? What is your code?
This sketch works, if I press the button the virtual LED activates, but then reboot the connection
char auth[] = "xxxxxxxxx";
WidgetLED led1(1);
   Blynk.begin(auth, "ssid", "password");
    // Wait until connected
  timer.setInterval(2000L, ButtonPress);
// Setup notification button on pin 13
  // Attach pin 13 interrupt
  attachInterrupt(13, ButtonPress, FALLING);
void ButtonPress()
  int isButtonPressed = digitalRead(13);
  if (isButtonPressed) {
    led1.on();
    BLYNK_LOG("LED1: on");
   else {
    led1.off();
   BLYNK_LOG("LED1: off");
I resolved not using interrupts
I also posted solution on instructable
[esp8266-12 standalone button virtualled][1]
[1]: http://www.instructables.com/id/ESP8266-12-blynk-wireless-simple-virtual-led/
char auth[] = "xxxxxxxxx"; //insert here your token generated by Blynk
WidgetLED led1(1); //virtual led
  Blynk.begin(auth, "ssid", "password!"); //insert here your SSID and password
 pinMode(13, INPUT); // gpio 13 input button
//----------------button virtual led---------------
  byte inp = digitalRead(13);
  if (inp == HIGH)
   led1.on();
   led1.off();
how can I control a relay instead of a virtual led and push the boton and change state of relay, then push again and return it back?
thanks!
Digital pins can be controlled directly by the app. No code is needed. Just add the button and set it to the pin, where relay is connected
Also, please do not hijack other’s threads. If you have a question create a new topic
I meant control a relay whith a physical button and the button in the app.
