Please edit your post, and add triple backticks ``` before and after your whole sketch.
And while you’re editing your post, please add-in information about what it is that you want hep with, what hardware you are using, and anything else that might help people understand the issue.
i need running the dht22 sensor wish blynk software
You code will be deleted if you don’t fix the formatting, and you wont get any useful assistance unless you provide more information, including the hardware you are using.
i use esp6288 but not woring the temperature sensor and humidity (DHT22) wish blynk app
i need fixed project
@mostafa.haj.husein im not sure what it is that you are trying to achieve here, but it’s clearly not working.
John has explained to you how to post code with the correct formatting, but you’ve ignored this.
As a result, your Unformatted code has been deleted.
I’d suggest that you start over, creating a new “need help with my project” topic and provide ALL of the requested information, and post your code between triple backticks, as is explained when you firts create the topic, and has also been explained by John above.
