Hc-sr04 ultrasonic sensor main.cpp code not working correctly (raspberry)
Please help with this code!
lost connect after a minute and wrong data to the blynk.
 * @file       main.cpp
 * @author     Volodymyr Shymanskyy
 * @license    This project is released under the MIT License (MIT)
 * @copyright  Copyright (c) 2015 Volodymyr Shymanskyy
 * @date       Mar 2015
 * @brief
//#define BLYNK_DEBUG
#define BLYNK_PRINT stdout
#ifdef RASPBERRY
  #include <BlynkApiWiringPi.h>
#else
  #include <BlynkApiLinux.h>
#endif
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
#include <sys/time.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
static const char *auth, *serv;
static uint16_t port;
#include <BlynkWidgets.h>
BLYNK_READ(10)
// Define GPIO to use on Pi ( wiringPI numbers )
int GPIO_TRIGGER=11;
int GPIO_ECHO=9;
//Compensate distance from edge to sensor
int COMP_SENSOR=0 ;
//Variables used by gettimeofday
struct timeval start, stop ;
// Set pins as output and input
wiringPiSetup () ;
  pinMode (GPIO_TRIGGER, OUTPUT) ;
  pinMode (GPIO_ECHO, INPUT) ;
//Set trigger to False (Low)
digitalWrite (GPIO_TRIGGER,  0) ;
//200 ms delay to start
delay (200) ;
//Send 10us pulse to trigger
digitalWrite (GPIO_TRIGGER,  1) ;
delayMicroseconds (10) ;
gettimeofday(&start, NULL) ;
while (digitalRead (GPIO_ECHO)==0)
while (digitalRead (GPIO_ECHO)==1)
gettimeofday(&stop, NULL) ;
// Calculate pulse length
float TIME_DELTA, DISTANCE ;
TIME_DELTA=(stop.tv_sec-start.tv_sec) + (stop.tv_usec-start.tv_usec) ;
// Distance pulse travelled in that time is time multiplied by the speed of sound (cm/s)
DISTANCE=TIME_DELTA * 34000 ;
// That was the distance there and back so halve the value
DISTANCE=DISTANCE / 2 ;
// Add compensation
DISTANCE=DISTANCE + COMP_SENSOR ;
// This command writes result to Virtual Pin (10) and convert usec to sec
Blynk.virtualWrite(10, DISTANCE  / 1000) ;
    Blynk.begin(auth, serv, port);
int main(int argc, char* argv[])
    parse_options(argc, argv, auth, serv, port);
    setup();
    while(true) {
        loop();
    return 0;
