Hello - I am working on a project where I got the BLE connection to work last week, but for some reason now I cannot connect. Also, on the app it says “BLE support is in prototyping and not available for standalone application”. Does this mean we cannot use the BLE function? I have tried switching ports, updating all libraries, refreshing the auth token, resetting, etc.
Here is my code:
Always use code formatting when pasting code
//to communicate with Blynk app
/************************** Global Variables *********************************/
// Question: How many motors can the battery power to still get strong vibrations?
// Want to make it so it only powers about 3-4 motors at the same time but rapid changes which motors vibrate
//Motor pin assignments
#define tl 5 //Top left motor is on pin 5
#define tr 6 //Top right motor is on pin 6
#define tp 7 // Top motor on pin 7
#define bm 8 // Top motor is on pin 8
#define bl 10 //Bottom left motor is on pin 10
#define br 11 //Bottom right motor is on pin 11
//Motor Pair Variables
int ma1 = tl; //Motor1 for pair a
int ma2 = bl; //Motor2 for pair a
int ma3 = tp; // Motor 3 for pair a
int mb1 = tr; //Motor1 for pair b
int mb2 = br; //Motor2 for pair b
int mb3 = bm; // Motor 3 for pair a
//Input Variables
int v = 0; //Vibration strength
int t = 300; //Time between alternations
// Want the timing of the switching of motor states to be every 300 milliseconds. Don't know if that means t should equal this or t1 shold equal this
int m = 1; //Motor alternation mode
int p = 0; //On/Off for watch vibration
//Vibration Variables
int motorState = 0; //Decides which motor pair to turn on/off
unsigned long t1; //Used to determine time between alternations
//Authentification code to connect to blynk
char auth[] = "vOK9rlIAxHERp7wE7MLCkQycJjgA5nbD";
// Need to change this for specific Blynk
// BLE Setup
Serial.begin(115200); //Initializes serial communications
Blynk.begin(Serial, auth); //Initializes Blynk start-up protocol
// Set up manual and BLYNK options
//Pin Setup
pinMode(tl,OUTPUT); //Set top left motor as an output
pinMode(tr,OUTPUT); //Set top right motor as an output
pinMode(tp, OUTPUT); // Set top motor as an output
pinMode(bl,OUTPUT); //Set bottom left motor as an output
pinMode(br,OUTPUT); //Set bottom right motor as an output
pinMode(bm, OUTPUT); // Set as outpit
//Get Inputs
//Assign Motors
assignMotors();
//Vibration Logic
if(p && Blynk.connected()){
vibrate();
}else{
stopVibrate();
p = 0;
//Method that chooses which motors alternate. Depending on what value is stored in m,
//which is determined by the value sent from the Blynk app, there will be different
//motor pairs assigned.
// This is where motor pairs (6) comes in
void assignMotors() {
//Left and Right
if(m == 1){
//Left Motors
ma1 = tl;
ma2 = bl;
mb3 = bm;
//Right Motors
mb1 = tr;
mb2 = br;
ma3 = tp;
// Figure out the timing of the vibrations and just make it constant
// Want to have two options: timing constant but also one that doesnt alternate vibrations and they are just always constant
//Method that turns on the motors. After t milliseconds of time have passed, it switches
//which motor pair is on and which is off.
void vibrate(){
if(millis()-t1 > t){
switchMotors(); //Switch motor vibration
t1 = millis(); //Reset time counter after the 7 patterns have been done
//This method switches which motor pair is vibrating. This is done using seven states.
void switchMotors(){
if(motorState == 0){
//Turn motor pair A on and B off
analogWrite(ma1,v);
analogWrite(ma2,v);
analogWrite(ma3,v);
analogWrite(mb1,0);
analogWrite(mb2,0);
analogWrite(mb3,0);
motorState = motorState + 1;
else if(motorState == 1)
//Turn motor pair A off and B on
analogWrite(ma1,0);
analogWrite(ma2,0);
analogWrite(ma3,0);
analogWrite(mb1,v);
analogWrite(mb2,v);
analogWrite(mb3,v);
else if(motorState == 2) {
analogWrite(ma1,v);
analogWrite(ma2,0);
analogWrite(ma3,v);
analogWrite(mb1,0);
analogWrite(mb2,v);
analogWrite(mb3,0);
else if(motorState == 3) {
analogWrite(ma1,0);
analogWrite(ma2,v);
analogWrite(ma3,0);
analogWrite(mb1,v);
analogWrite(mb2,0);
analogWrite(mb3,v);
else if(motorState == 4) {
analogWrite(ma1,v);
analogWrite(ma2,v);
analogWrite(ma3,0);
analogWrite(mb1,0);
analogWrite(mb2,v);
analogWrite(mb3,0);
else if(motorState == 5) {
analogWrite(ma1,v);
analogWrite(ma2,0);
analogWrite(ma3,v);
analogWrite(mb1,v);
analogWrite(mb2,0);
analogWrite(mb3,0);
else if(motorState == 6) {
analogWrite(ma1,v);
analogWrite(ma2,0);
analogWrite(ma3,0);
analogWrite(mb1,0);
analogWrite(mb2,v);
analogWrite(mb3,v);
motorState = 0;
//This method turns off all the motors.
void stopVibrate(){
//Turn off all motors
analogWrite(ma1,0);
analogWrite(ma2,0);
analogWrite(ma3,0);
analogWrite(mb1,0);
analogWrite(mb2,0);
analogWrite(mb3,0);
/************* BLYNK LIBRARY METHODS *************************/
//These methods are called whenever a button is pressed or
//a slider is moved on the app. When Blynk sends a value to
//the Arduino, that value is stored in a variable depending
//on which slider/button is pressed.
//Assign V0 to v
BLYNK_WRITE(V0)
v = param.asInt();
//Assign V1 to t
BLYNK_WRITE(V1)
t = param.asInt();
//Assign V2 to m
BLYNK_WRITE(V2){
m = param.asInt();
//Assign V3 to p
BLYNK_WRITE(V3){
p = param.asInt();
