Having Problem with BLYNK_WRITE(InternalPinRTC) compile error
I have this very long sketch that I am trying to use the RTC and get it synchronized quickly. When I add the following code from the Advanced RTC example:
BLYNK_WRITE(InternalPinRTC) {
long t = param.asLong();
Serial.print("Unix time: ");
Serial.print(t);
Serial.println();
I get a bunch of complies errors:
In file included from /Users/Kurt/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/Ethernet/src/Dhcp.h:7:0,
from /Users/Kurt/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/Ethernet/src/Ethernet.h:9,
from /var/folders/2b/fgk4_0b13bl41w3jww7ndhpw0000gp/T/arduino_modified_sketch_869044/NTP_TimeFunctions.ino:43:
/Users/Kurt/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/Ethernet/src/EthernetUdp.h:42:0: warning: “UDP_TX_PACKET_MAX_SIZE” redefined [enabled by default]
#define UDP_TX_PACKET_MAX_SIZE 24
In file included from /var/folders/2b/fgk4_0b13bl41w3jww7ndhpw0000gp/T/arduino_modified_sketch_869044/WeatherServerBlynkNPTBlynkTimeTemp.ino:49:0:
/Users/Kurt/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/WiFiUdp.h:28:0: note: this is the location of the previous definition
#define UDP_TX_PACKET_MAX_SIZE 8192
/var/folders/2b/fgk4_0b13bl41w3jww7ndhpw0000gp/T/arduino_modified_sketch_869044/A_Functions.ino:195:1: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
In file included from /Users/Kurt/Documents/ArduinoNew/libraries/AdafruitGFXLibrarymaster/Adafruit_GFX.cpp:35:0:
/Users/Kurt/Documents/ArduinoNew/libraries/AdafruitGFXLibrarymaster/glcdfont.c:8:0: warning: “PROGMEM” redefined [enabled by default]
#define PROGMEM
In file included from /Users/Kurt/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/Arduino.h:256:0,
from /Users/Kurt/Documents/ArduinoNew/libraries/AdafruitGFXLibrarymaster/Adafruit_GFX.h:5,
from /Users/Kurt/Documents/ArduinoNew/libraries/AdafruitGFXLibrarymaster/Adafruit_GFX.cpp:34:
/Users/Kurt/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/pgmspace.h:13:0: note: this is the location of the previous definition
#define PROGMEM ICACHE_RODATA_ATTR
/Users/Kurt/Documents/ArduinoNew/libraries/AdafruitGFXLibrarymaster/Adafruit_GFX.cpp:39:0: warning: “pgm_read_byte” redefined [enabled by default]
#define pgm_read_byte(addr) (*(const unsigned char *)(addr))
/Users/Kurt/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/pgmspace.h:123:0: note: this is the location of the previous definition
#define pgm_read_byte(addr) pgm_read_byte_inlined(addr)
with out these lines I get:
from /var/folders/2b/fgk4_0b13bl41w3jww7ndhpw0000gp/T/arduino_modified_sketch_293346/NTP_TimeFunctions.ino:43:
In file included from /var/folders/2b/fgk4_0b13bl41w3jww7ndhpw0000gp/T/arduino_modified_sketch_293346/WeatherServerBlynkNPTBlynkTimeTemp.ino:49:0:
/var/folders/2b/fgk4_0b13bl41w3jww7ndhpw0000gp/T/arduino_modified_sketch_293346/A_Functions.ino:195:1: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
Sketch uses 340540 bytes (32%) of program storage space. Maximum is 1044464 bytes.
Global variables use 38656 bytes (47%) of dynamic memory, leaving 43264 bytes for local variables. Maximum is 81920 bytes.
