HOLO81
1
I have Hardware to software problem.
I want to light a led on the app with a physical button.
I use Arduino Wemos D1 R1. The connection is well established with my phone but it is my code that must not be good I think.
My code :
> #define BLYNK_PRINT Serial
> #include <ESP8266WiFi.h>
> #include <BlynkSimpleEsp8266.h>
> char auth[] = "**********************";
> char ssid[] = "************";
> char pass[] = "*******************";
> const int btnPin = 2;
> WidgetLED led3(V0);
> BlynkTimer timer;
> // V3 LED Widget represents the physical button state
> boolean btnState = false;
> void buttonLedWidget()
> // Read button
> boolean isPressed = (digitalRead(btnPin) == LOW);
> // If state has changed...
> if (isPressed != btnState) {
> if (isPressed) {
> led3.on();
> } else {
> led3.off();
> btnState = isPressed;
> void setup()
> Blynk.begin(auth, ssid, pass);
> // Setup physical button pin (active low)
> pinMode(btnPin, INPUT_PULLUP);
> timer.setInterval(500L, buttonLedWidget);
> void loop()
> Blynk.run();
> timer.run();
I hope you can help me
// Read button
This is a little strange to me. Maybe try something like this:
int btnState = 2; //not 1 or 0 so the function will always run once at boot
// Read button
> int isPressed = digitalRead(btnPin) ;
HOLO81
3
Thanks for your answer, I tested but it does not change any reaction on the side of the app. If you need more details I can give you what you want
Code after modification :
> char auth[] = "*****************";
> char ssid[] = "*****************";
> char pass[] = "*****************";
> WidgetLED led3(V0);
> BlynkTimer timer;
> int btnState = 2;
> if (isPressed) {
> led3.on();
> } else {
> led3.off();
> void setup()
> void loop()
> Blynk.run();
> timer.run();
it is working for me. I changed to pin to work with my board.
Double check that you are using the correct pin. D2 is NOT GPIO2.
char auth[] = "";
char ssid[] = "";
char pass[] = "";
const int btnPin = 14;
WidgetLED led3(V0);
int btnState = 2;
if (isPressed) {
led3.on();
led3.off();
HOLO81
5
Ok, Thanks a lot iām just using wrong output
I have one more question, if I want through this button increment a variable on the application is this possible and how can i do ?
You are the best
Here is an example:
char auth[] = "";
char ssid[] = "";
char pass[] = "";
WidgetLED led3(V0);
int btnState = 2;
int counter = 0;
if (isPressed) {
led3.on();
Serial.println("ON");
led3.off();
counter++;
Blynk.virtualWrite(V2, counter);
Serial.println(counter);
Serial.println("OFF");
HOLO81
7
Thanks a lot ! I just want to do one last thing is add a button on the app that can reset the counter if you have this you are the best !
BLYNK_WRITE(V3) \\ virtual blynk button in push mode
counter=0;
