Hard working with widget led
Hi everyone
I have a problem with adding another LED_SatusOfButton and DTH11
I will be grateful for help
> #define BLYNK_PRINT Serial
> #include <ESP8266_Lib.h>
> #include <BlynkSimpleShieldEsp8266.h>
> #include <SimpleTimer.h>
> char auth[] = "xdxd";
> char ssid[] = "name";
> char pass[] = "pass";
> #include <SoftwareSerial.h>
> SoftwareSerial EspSerial(12, 13); // RX, TX
> #define ESP8266_BAUD 9600
> ESP8266 wifi(&EspSerial);
> const int btnPin = 7;
> WidgetLED led3(V3);
> SimpleTimer timer;
> void setup()
>   Serial.begin(9600);
>   delay(10);
>   EspSerial.begin(ESP8266_BAUD);
>   delay(10);
>   Blynk.begin(auth, wifi, ssid, pass);
>   pinMode(btnPin, INPUT_PULLUP);
>   while (Blynk.connect() == false) {
>   timer.setInterval(500L, buttonLedWidget);
> boolean btnState = false;
> void buttonLedWidget()
>     boolean isPressed = (digitalRead(btnPin) == LOW);
>   if (isPressed != btnState) {
>    if (isPressed) {
>       led3.on();
>    } else {
>       led3.off();
>     btnState = isPressed;
> void loop()
>  Blynk.run();
>   timer.run();
@lesniakrafael that’s the first sketch I have seen with no lines of code.
I would suggest you change your IDE to one that gives you something like this:
   #include
   //SoftwareSerial EspSerial(12, 13);     RX, TX
   WidgetLED led3(V3);
       if (isPressed)
        led3.on();
       else {
          led3.off();
I have guessed 3 of your 4 missing includes. The other will be for DHT11. Please provide details of the include and format it with the </> menu item.
If you are not going to make the sketch easy for us to read we are not going to spend too much time trying to help you.
Please explain in great detail what problem means, we are not clairvoyants.
thanks @Costas I corrected post
Okey
I did this sketch but I don’t know what to do next
I want to add to it another WidgetLED led_(__);
And program to DHT11 in Celcius (illustrative photo) like this
I need someone to show me how to write it
Have you used DHT11 before using Blynk?
See how you go with this http://www.instructables.com/id/ESP8266-12-blynk-wireless-temperature-e-humidity-D/ and remember Google is your friend.
This Skatch work very well I added one WidgetLED and term DTH11
But still I can’t add secound WidgetLED
    #include <DHT.h>
    #define DHTPIN 4
    #define DHTTYPE DHT11
    DHT dht(DHTPIN, DHTTYPE);
    WidgetLED led3(V3);
      dht.begin();
    if (isPressed) {
    led3.on();
    led3.off();
    void sendSensor()
      float h = dht.readHumidity();
      if (isnan(h) || isnan(t)) {
        return;
      Blynk.virtualWrite(V5, h);
      Blynk.virtualWrite(V6, t);
You have WidgetLED led3(V3) why not try also ading WidgetLED ledx(Vy) .
I added buy not working
Just use the following then:
Blynk.virtualWrite(Vx, 255);  // to turn LED x ON
Blynk.virtualWrite(Vx, 0);     // to turn LED y OFF
How to this code add other buttonLedWidget
I need 3 another one LedWidget
    #include <DHT.h>
    char auth[] = "6855967bde5149eaba665c4863dc7e77";
    #define DHTPIN 5
    const int btnPin = 22;
    WidgetLED led3(V3);
    char ssid[] = "Salon";
    char pass[] = "administrator";
    #define EspSerial Serial1
    //#include <SoftwareSerial.h>
    // Your ESP8266 baud rate:
      // Set console baud rate
      // Set ESP8266 baud rate
       dht.begin();
        // Wait until connected
    void sendSensor()
        return;
      // Read button
      // If state has changed...
        if (isPressed) {
          led3.on();
          led3.off();
