GSP TRACKER, SIGFOX, MAPs WIDGET
Hi community.
From my GPS tracker I get data to SIGFOX backend. And from here I want push it with callbacks to MAPS WIDGET with URL PATTERN. It’s possible in this moment?
I can send FLOAT using the PATTERN URL to the Labeled Value widget, that’s not a problem.
Has anyone else solved this problem? How to compile the URL command? Thanks
