I have a problem with the connection to the blynk server via GSM. The connection closed after a few seconds and can connect again. Any ideas why that could be?
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
Wait...
Initializing modem...
[10550] ### TinyGSM Version: 0.11.4
[10550] ### TinyGSM Compiled Module: TinyGsmClientSIM800
[10861] ### Modem: SIMCOM SIM800L
Modem Info: SIM800 R14.18
[13891]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.0 on ESP32
[13895] Modem init...
[13897] ### TinyGSM Version: 0.11.4
[13900] ### TinyGSM Compiled Module: TinyGsmClientSIM800
[13919] ### Modem: SIMCOM SIM800L
[13936] Connecting to network...
[17763] Network: D1
[17763] Connecting to internet.t-mobile ...
[21773] Connected to GPRS
[31397] Connecting to blynk-cloud.com:80
[35989] Ready (ping: 238ms).
[71224] Connecting to blynk-cloud.com:80
[149230] Connecting to blynk-cloud.com:80
[227236] Connecting to blynk-cloud.com:80
[305242] Connecting to blynk-cloud.com:80
here the skech
For this example, you need to install Blynk library:
TinyGSM Getting Started guide:
https://tiny.cc/tinygsm-readme
Blynk supports many development boards with WiFi, Ethernet,
GSM, Bluetooth, BLE, USB/Serial connection methods.
See more in Blynk library examples and community forum.
http://www.blynk.io/
Change GPRS apm, user, pass, and Blynk auth token to run :)
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
// Please select the corresponding model
#define SIM800L_IP5306_VERSION_20190610
//#define SIM800L_AXP192_VERSION_20200327
// #define SIM800C_AXP192_VERSION_20200609
// #define SIM800L_IP5306_VERSION_20200811
#include "utilities.h"
// Select your modem:
#define TINY_GSM_MODEM_SIM800
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// See all AT commands, if wanted
//#define DUMP_AT_COMMANDS
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// set GSM PIN, if any
#define GSM_PIN ""
// Your GPRS credentials, if any
const char apn[] = "internet.t-mobile"; // search for apn of your network provider on Google
const char gprsUser[] = "t-mobile";
const char gprsPass[] = "tm";
const char auth[] = "oXXXXXXXXXXXXXXXXXXX01";
#include <TinyGsmClient.h>
#include <Adafruit_NeoPixel.h>
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN 2
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 28
// NeoPixel brightness, 0 (min) to 255 (max)
#define BRIGHTNESS 200 // Set BRIGHTNESS to about 1/5 (max = 255)
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRBW + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
#endif
TinyGsmClient client(modem);
// set the LCD number of columns and rows
int lcdColumns = 16;
int lcdRows = 2;
// set LCD address, number of columns and rows
// if you don't know your display address, run an I2C scanner sketch
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows);
WidgetLED led1(V0);
WidgetLED led2(V1);
WidgetLCD lcd2(V2);
int LED1=32, tasterPin1=14;
int LED2=33, tasterPin2=12;
int tasterPin3=15;
struct StoppUhr // alles was für eine Stoppuhr benötigt wird
const byte pinStart;
const byte pinStop;
const byte pinReset;
unsigned long timeStart;
unsigned long timeStop;
unsigned long time;
bool active;
bool resume;
bool blink;
byte oldSecond;
StoppUhr (byte p1, byte p2, byte p3) :
// Initialisierungsliste;
pinStart {p1},
pinStop {p2},
pinReset {p3},
timeStart {0},
timeStop {0},
time {0},
active {false},
resume {false},
blink{false}, // für ':' Schönheitskorrektur auf dem Display
oldSecond {255} // überhöhter Startwert für 0 Ausgabe auf Lcd
StoppUhr arrayUhr[]
{ // Pins der Taster
{12, 14, 15}, // rot, blau, stopAll
{14, 12, 15}, // blau, rot, stopAll
const byte ANZAHLUHREN = sizeof(arrayUhr) / sizeof(arrayUhr[0]);
for (auto &i : arrayUhr)
pinMode(i.pinStart, INPUT_PULLUP);
pinMode(i.pinStop, INPUT_PULLUP);
pinMode(i.pinReset, INPUT_PULLUP);
pinMode(tasterPin1,INPUT_PULLUP);
pinMode(tasterPin2,INPUT_PULLUP);
pinMode(tasterPin3,INPUT_PULLUP);
pinMode(LED1,OUTPUT);
pinMode(LED2,OUTPUT);
// Set console baud rate
SerialMon.begin(115200);
setupModem();
SerialMon.println("Wait...");
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(6000);
SerialMon.println("Initializing modem...");
modem.restart();
// modem.init();
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem Info: ");
SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
Blynk.begin(auth, modem, apn, gprsUser, gprsPass);
SPI.begin();
// initialize LCD
lcd.init();
// turn on LCD backlight
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0); lcd.print("ROT :");
lcd.setCursor(0, 1); lcd.print("BLAU:");
//lcd2.print(0, 0, "ROT :");
//lcd2.print(0, 1, "BLAU:");
strip.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
strip.show(); // Turn OFF all pixels ASAP
strip.setBrightness(BRIGHTNESS);
leds();
eingabe();
ausgabe();
void leds (void)
if (digitalRead(tasterPin1) && !digitalRead(tasterPin2))
digitalWrite(LED1,HIGH);
led1.on();
digitalWrite(LED2,LOW);
led2.off();
strip.setPixelColor(0, 255, 0, 0); // Red
if (digitalRead(tasterPin2) && !digitalRead(tasterPin1))
digitalWrite(LED2,HIGH);
led2.on();
digitalWrite(LED1,LOW);
led1.off();
strip.setPixelColor(0, 0, 0, 255); // Blue
if (!digitalRead(tasterPin3))
led1.off();
led2.off();
strip.clear();
void eingabe (void)
unsigned long loopMillis = millis();
// Uhr wird neu gestartet
if ( !digitalRead(i.pinStart) && !i.active && !i.resume )
i.timeStart = loopMillis;
i.active = true;
// wenn Resuming aktiv läuft Uhr mit alter Zeit weiter
// wird einmalig abgearbeitet
if ( !digitalRead(i.pinStart) && !i.active && i.resume )
// alte Zeitdifferenz ermitteln und von aktuellen millis abziehen
i.timeStart = loopMillis - (i.timeStop - i.timeStart);
i.active = true;
i.resume = false;
// Uhr wird gestoppt unter der Bedingung das sie überhaupt läuft,
// und fürs spätere weiterlaufen vorbereitet
if ( i.active && (!digitalRead(i.pinStop)) )
i.active = false;
i.resume = true;
i.timeStop = loopMillis;
// ansonsten gibts unschöne Effekte
// und für Neustart Nullung vorbereitet
if ( !digitalRead(i.pinReset) )
i.active = false;
i.resume = false;
// laufende Zeit ermitteln
if ( i.active )
i.time = loopMillis - i.timeStart;
void ausgabe (void)
byte hour {0};
byte minute {0};
byte second {0};
char buf[10] {'\0'};
// Index vom Uhren Array dient mit zur Zeilenbestimmung auf dem Display.
for (byte i = 0; i < ANZAHLUHREN; i++)
unsigned long temp = arrayUhr[i].time / 1000;
second = temp % 60;
temp = temp / 60;
minute = temp % 60;
hour = temp / 60;
//snprintf(buf, sizeof(buf), "%02d:%02d:%02d", hour, minute, second);
// display refreshrate every seconds
if ( arrayUhr[i].oldSecond != second )
lcd.setCursor(6, i);
lcd.print(buf);
lcd2.print(0, 0, "ROT ");
lcd2.print(0, 1, "BLAU");
lcd2.print(6, i, buf);
arrayUhr[i].oldSecond = second;
// Resume Warteanzeige - optische Spielerei - blinkende Doppelpunkte
static unsigned long lastMillis {0};
//static bool blink {false};
if ( arrayUhr[i].resume )
if (millis() - lastMillis >= 1000)
arrayUhr[i].blink = !arrayUhr[i].blink;
if (arrayUhr[i].blink)
lcd.setCursor(8, i); lcd.print(' ');
lcd.setCursor(11,i); lcd.print(' ');
//lcd2.print(8, i, ' ');
//lcd2.print(11,i, ' ');
lcd.setCursor(8, i); lcd.print(':');
lcd.setCursor(11,i); lcd.print(':');
//lcd2.print(8, i, ':');
//lcd2.print(11,i, ':');
lastMillis = millis();
// Resume Warteanzeige - Schönheitskorrektur
// falls Uhr gestoppt bzw. resetet wird und ':' zufällig ausgeblendet war,
// dann wird das Zeichen einmal neu dargestellt.
if ( !arrayUhr[i].resume && arrayUhr[i].blink)
arrayUhr[i].blink = false;
} // Ende for
With the wifi connection there are no problems with the sketch.
With 3 or 4 simple on / off buttons and leds the sketch works fine with GSM connection and the connection is stable.
