Have started to create my first project: UNO - W5100 - MAX6675 (temperature sensor).
I am bit exploring what is the best view for a BBQ temperature reading.
I have set on my tablet a value with a reading frequency of 3 seconds and a graph with a reading frequency of 30 seconds.
My loop delay on the UNO is 3 seconds
My question: why is a bar added in the graph in a faster frequency than 30 seconds?
Can I invluence this?
I also like the historical graph but want to cover the last 3 minutes.
Hi, thanks for your response. Everything is working perfectly, but I expected that setting graph frequency to 30 seconds I get 1 bar each 30 seconds. (I realize this is getting close to the historical graph). I saw the BLYNCK_READ remark in the help function but was not sure how to use this. Below my code:
(also manage to read forum instructions around publishing code)
//http://creativecommons.org/licenses/by-sa/3.0/
//https://github.com/mcleng/MAX6675-Library
//http://datasheets.maximintegrated.com/en/ds/MAX6675.pdf
#include <Ethernet.h>
char auth[] = "xxx";
#define W5100_CS 10
#define SDCARD_CS 4
#include <MAX6675.h>
// left_2_right: GND - VCC - SCK - CS - SO
//int LED1 = 9; // Status LED Pin
int CS = 5; // CS pin on MAX6675
int SO = 6; // SO pin of MAX6675
int NCK = 4; // SCK pin of MAX6675 (variable SCK cannot be used reserved for RTC)
int units = 1; // Units to readout temp (0 = raw, 1 = ËšC, 2 = ËšF)
float temperature = 0.0; // Temperature output variable
int t;
// Initialize the MAX6675 Library for our chip
MAX6675 temp(CS,SO,NCK,units);
// Setup Serial output and LED Pin
// MAX6675 Library already sets pin modes for MAX6675 chip!
//pinMode(LED1, OUTPUT);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
// You can also specify server.
// For more options, see BoardsAndShields/Arduino_Ethernet_Manual example
//Blynk.begin(auth, "your_server.com", 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
// Read the temp from the MAX6675
temperature = temp.read_temp();
t = temperature;
Blynk.virtualWrite(22, temperature); //blynck graph=30sec (expect 1 bar for each 30 seconds)
Blynk.virtualWrite(21, t); //blynck value=3sec + history graph
// Wait one second before reading again
delay(3000);
