GPS Trigger
Hello
can someone tell me if the code is so correct in the GPS trigger because the LED color in the blynk app does not change when I’m out of range bw within the range
#include <Fishino.h>
#include <BlynkSimpleFishino.h>
char pass[] = "YourPassword";
WidgetLED led6(V3);
BLYNK_WRITE(V5) {
  int state = param.asInt();
  if (state) {
      led6.on();
   Blynk.setProperty(V3, "color", "#FF00FF");
      led6.on();
   Blynk.setProperty(V3, "color", "#3ADF00");
the code seems ok for me.
  • what is “state” representing (v5)?
  • put some serial println near the led6.on lines in the if else conditions, to see if they actually get executed
  • if all the above are correct, try a simpler led function, just turn on the led in if and turn off in else. setproperty features is buggy sometimes…
    or just use a simple display widget with some text, for testing
hello does not work with the GPS trigger
char auth[] = "768aee3d0c3a4e60bdc643fxxxxx";
SoftwareSerial SerialBLE(10, 11); // RX, TX
WidgetLCD lcd(V1);
BLYNK_WRITE(V5) {
  if (state) {
      digitalWrite(3, HIGH);
      Serial.println("LED an");
      lcd.clear();
      lcd.print(4,1, "Hello");
      digitalWrite(3, LOW);
      Serial.println("LED aus");
      lcd.clear();
      lcd.print(4,1, "world");
pinMode(3, OUTPUT);
  SerialBLE.begin(9600);
  Blynk.begin(SerialBLE, auth);
@markop formatting uses three backticks, not three commas :wink:
Blynk - FTFC
yes sorry :Grinsen: I still do not understand why it does not trigger the GPS trigger when you leave the area yes, for example, the Led on or off go
Maybe a BLE issue… might need server access? Try searching this forum for GPS Trigger… see if any other suggestions or examples work.
https://community.blynk.cc/search?q=gps%20trigger%20order%3Alatest
