GPS Triger
I am using GPS Trigger. I need to be able to set two geofences, one for entrance and one for exit (each with different radius). When I am editing the App and entering geofencing information into the widget all works OK. I understand that the way to enter the geofencing information when the App is running is through Map widget. How do I enter two different geofencing with the Map widget. Even if I will be using two Maps widget, how do you link each map to a trigger?
Sharon
I didn’t get any answer on this. Maybe someone from Blynk can answer this question?
