Hello, I have a sketch running that gets the location from a GPS device. This data is send into virtual values in Blynk. The V7 String variable contains the location : index, lat, long. Index is set to 1 or 0 (tried both)
When I use the second method, a cursor is placed somewhere near the coast of Nigeria … but my device is based in Belgium. I am pretty sure the LAT & LON values are correct.
Well, the map command is NOT interpreting them that way… perhaps you need to take your gps.location.lat() and transfer that to a float variable, then use that variable for the map command… same for the gps.location.lng()
This works indeed ! But what is the difference then with the myMap.location(1, Current_LAT, Current_LON, “value”); ? And what options do you have with “value” ?
