What @Toro_Blanco is suggesting, is that you request a new auth token - you can do this in the app.
Then use the new token in both your code and the URL
The auth code and IP address are correct…
http://188.166.206.43/_jyBKmVIc4lcdQqbxtQhV86t_XnIoDIQ/project
So it seems there may be a mix-up between the “I” (Upper Case i) and “l” (Lower Case L)
Which on here both appear the same.
http://188.166.206.43/_jyBKmVIc4lcdQqbxtQhV86t_XnIoDIQ/update/V3?value=1
Now go and refresh you auth code, as now we can manipulate your device via URL.
