Have you read this topic? Did you understand it?
I had gone through it, but i need Indian blink id
Thanks a lot guys, it worked.
:sorrindo:
Hello Gazalasoofi. Follow this step by step. First of all, you need a blynk design with a knob to control, for example, an LED or a relay. Then download IFTTT from the Google Play Store (https://goo.gl/snr4DQ 337) or the Apple Store (https://goo.gl/FXz1f2 36) Now open IFTTT, go to âMy appletsâ and tap add in the upper right corner, click âthatâ and find the âGoogle Assistantâ. After that, choose a trigger and complete all the phrases in the chosen trigger, click on the tick. In the right corner, select âthatâ, find âWebhooksâ, âmake a web requestâ and now in the URL you need to put "http: // YOUR_COUNTRY_BLYNK_IP / YOUR_TOKEN_HERE / update / D7 (D7 = digital 7, switch to turn on or off the pin you want) what iâm using is (v2 = virtual 2) to find blynkâs ip for your country, just go to the PC command line and type: ping cloud.blynk.) from my country (Brazil) is IP 45.55.96.146 To call: https://45.55.96.146/27xxxxxxxxxxxxxxxxxxxxxxxxxxxxc8aafc/update/V2?value=0 Turn off: https://45.55.96.146/27xxxxxxxxxxxxxxxxxxxxxxxxxxxxc8aafc/update/V2?value=1 Paste it into the URL in IFTTT, choose the method for âGETâ, âContent Typeâ for "application / Json. Now save everything, call your assistant and ask for the phrase you choose, after which the pin you choose will be ON or OFF.
