Press button from android Blynk, LED on ESP8266 responses correctly. But the .getValue() is only 0 result.
WidgetLED led5( ledPin );
void blynkLedWidget()
int Value = led5.getValue( );
Serial.print( "value: "); // this line always print "0" ?????????
Serial.println( Value);
if (Value == 1 ) {
led5.on();
Serial.println("LEd on D5: ON");
led5.off();
Serial.println("LED on D5: OFF");
pinMode( ledPin, OUTPUT);
timer.setInterval( 3000L, blynkLedWidget);
SamiraNSamilan:
if (Value == 1 ) {
shoud be 255 instead of 1. - http://docs.blynk.cc/#widgets-displays-led
It still does not give me the 255 , still get 0.
BTW, I used the digital pin in the button pin widget selection. Does it make any difference ?
int ledPin = 5;
Yes. WidgetLED is the abstraction over widget LED within the Application and not hardware.
Also you code is wrong. You need to change places of on()
on and off()
. We have ready example for that - https://github.com/blynkkk/blynk-library/blob/master/examples/Widgets/LED/LED_Blink/LED_Blink.ino
Still does not work.I get this result.
LEd on D5: ON
value: 0
LED on D5: OFF
value: 0
LEd on D5: ON
value: 0
LED on D5: OFF
value: 0
If one wants to use the digital pin in the button selection, How does one do to check the value on ESP side ?
BTW, on the button widget, I select the ‘switch’.
Gunner
July 25, 2017, 7:17am
6
