Hi everyone, need help with getting data in app. I use Arduino Mega, HC-06 bluetooth and last versions of library and app. And connection works only one way-i can control my Arduino, but can’t get any data back. In other apps (bluetooth terminals etc.) it works correctly(get and send), but not in blynk. Onse it started working, but after hitting a reset button-nothing again. App sometimes show status “online”, sometimes not.
P.S. HC-06 is hardware Serial1.
P.P.S. Sorry for my English.
char auth[] = "y31V9DpLlQX66Ysm0zjwoOclE1AYs_Zt";
void myTimerEvent()
int Sensor=analogRead(A0);
Blynk.virtualWrite(V5, Sensor);
Serial1.begin(9600);
Blynk.begin(Serial1, auth);
