Need some help with my project Code.
we are Aiming for consistent timing with the Millis function when using Blynk, but as we use the Blynk we are getting additional second on timing.
we set the Timing for the relay to open for 1 min and close for 1 min as a trial but instead we get additional 10 seconds on the timing for both on and off.
please help badly wanted to graduate T_T
#include <Wire.h>
#include <dht.h>
///////////////IOT
#include <ESP8266_Lib.h>
char auth[] = "";
char ssid[] = ""; //wifiname
char pass[] = ""; //pass
#define EspSerial Serial2
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
#define ONE_WIRE_BUS 2
#define DHT1_PIN 3
#define DHT2_PIN 4
#define DHT3_PIN 8
#define DHT4_PIN 9
#define ldr_pin2 6
#define Relay8 52 //Pump
#define Relay7 50 //Peristaltic
#define Relay6 48 //pH up
#define Relay5 46 //ph Down
#define Relay4 44 //peltier
#define Relay3 42 //Growlights
dht DHT1;
dht DHT2;
dht DHT3;
dht DHT4;
LiquidCrystal_I2C lcd(0x27, 16, 2);
float Celcius=0;
float Fahrenheit=0;
float calibration_value = 21.34;
int phval = 0;
unsigned long int avgval;
int buffer_arr[10], temp;
float ph_act;
int Relay8state= LOW;
int Relay7State= LOW;
int Relay6State= LOW;
int Relay5State= LOW;
unsigned long previouspump = 0;
unsigned long previoustemp = 0;
unsigned long previoushumi = 0;
unsigned long previouspup = 0;
unsigned long previousdown = 0;
long OnTime = 60000; // 1min often outburst
long OffTime = 60000; // 1mins often outburst
long OnTime1 = 90000; // 1min normal
long OffTime1 = 90000; // 7mins normal
long OT = 3000; // 5 sec temp
long FT = 3000; // 5 sec temp
long POT = 1000; // 1 sec ph
Blynk.begin(auth, wifi, ssid, pass, "blynk.cloud", 80);
timer.setInterval(1000L, sendSensors);
sensors.begin();
lcd.init();
lcd.backlight();
pinMode(DHT1_PIN, INPUT);
pinMode(DHT2_PIN, INPUT);
pinMode(DHT3_PIN, INPUT);
pinMode(DHT4_PIN, INPUT);
pinMode(Relay8, OUTPUT);
pinMode(Relay7, OUTPUT);
pinMode(Relay6, OUTPUT);
pinMode(Relay5, OUTPUT);
pinMode(Relay4, OUTPUT);
pinMode(Relay3, OUTPUT);
pinMode(ldr_pin2,INPUT);
digitalWrite(Relay8, HIGH);
digitalWrite(Relay7, HIGH);
digitalWrite(Relay6, HIGH);
digitalWrite(Relay5, HIGH);
digitalWrite(Relay4, HIGH);
digitalWrite(Relay3, HIGH);
void sendSensors(){
Blynk.virtualWrite(V0, millis() / 1000);
if(Fahrenheit >71){ //temparature codition code
unsigned long currenttemp = millis();
if((Relay7State == HIGH) && (currenttemp - previoustemp >= OT))
Relay7State = LOW; // Turn it off
previoustemp = currenttemp; // Remember the time
digitalWrite(Relay7, Relay7State); // Update
else if ((Relay7State == LOW) && (currenttemp - previoustemp >= FT))
Relay7State = HIGH; // turn it on
}//end temp
/////////////////////////////////////////////////////////////////////////////////// if humidity sensor is less than 60 more frequenct outburst
if ((DHT1.humidity<=60)&&(DHT2.humidity <= 60)&&(DHT3.humidity <= 60)&&(DHT4.humidity <= 60)){ //start humidity sensors
unsigned long currenthumi = millis();
if((Relay8state == LOW) && (currenthumi - previoushumi >= OnTime))
Relay8state = HIGH; // Turn it off
previoushumi = currenthumi; // Remember the time
digitalWrite(Relay8, Relay8state); // Update
Blynk.virtualWrite(V5,"Normal Humidity");
else if ((Relay8state == HIGH) && (currenthumi - previoushumi >= OffTime))
Relay8state = LOW; // turn it on
Blynk.virtualWrite(V5,"Misters on due to low humidity");
}//end humidity
//////////////////////////////////////////////////////////////////////////////////////// if humidity sensor is greater than 60 Less frequenct outburst
if ((DHT1.humidity>=60)&&(DHT2.humidity >= 60)&&(DHT3.humidity >= 60)&&(DHT4.humidity >= 60)){ //start humidity sensors
if((Relay8state == LOW) && (currenthumi - previoushumi >= OnTime1))
else if ((Relay8state == HIGH) && (currenthumi - previoushumi >= OffTime1))
}//end humidity
TEMPSENSOR();
Growlights();
WATERLVLSENSOR();
DHT();
PH();
PHUPDOWN();
coolingsystem();
}//loop
void TEMPSENSOR(){
Celcius=sensors.getTempCByIndex(0);
Fahrenheit=sensors.toFahrenheit(Celcius);
Blynk.virtualWrite(V7,Fahrenheit);
lcd.setCursor(1, 0);
lcd.print("Reservoir Temp");
lcd.setCursor(5, 1);
lcd.print( Fahrenheit);
lcd.print((char)223);
lcd.print("F");
lcd.clear();
void coolingsystem(){
if(Fahrenheit >71){
digitalWrite(Relay4, LOW);
Blynk.virtualWrite(V8,"High Temperature - Cooling system on");
else {
Blynk.virtualWrite(V8,"Normal Temperature");
void PHUPDOWN(){
if (ph_act <= 5.9){//start pH Up Peristaltic
digitalWrite(Relay6, Relay6State); // Update
Blynk.virtualWrite(V10,"pH lvl low-pH - up ON");
delay(POT);
delay(POT);
if (ph_act >= 7.1){//start pH Down Peristaltic
digitalWrite(Relay5, Relay5State); // Update
Blynk.virtualWrite(V10,"pH lvl High_pH - down ON");
delay(POT);
delay(POT);
void PH(){
for (int i = 0; i < 10; i++)
buffer_arr[i] = analogRead(A1);
delay(30);
for (int i = 0; i < 9; i++)
for (int j = i + 1; j < 10; j++)
if (buffer_arr[i] > buffer_arr[j])
temp = buffer_arr[i];
buffer_arr[i] = buffer_arr[j];
buffer_arr[j] = temp;
avgval = 0;
for (int i = 2; i < 8; i++)
avgval += buffer_arr[i];
float volt = (float)avgval * 5.0 / 1024 / 6;
float ph_act = -5.70 * volt + calibration_value;
lcd.setCursor(0, 0);
lcd.print("pH Val:");
lcd.setCursor(8, 0);
lcd.print(ph_act);
Blynk.virtualWrite(V9,ph_act);
lcd.clear();
void Growlights(){
if( digitalRead( ldr_pin2 ) == 1){
digitalWrite( Relay3, LOW);
Blynk.virtualWrite(V11,"Growlights ON");
else{
digitalWrite( Relay3 , HIGH);
Blynk.virtualWrite(V11,"Growlights OFF");
void DHT(){
int DHT1CHECK = DHT1.read11(DHT1_PIN);
int DHT2CHECK = DHT2.read11(DHT2_PIN);
int DHT3CHECK = DHT3.read11(DHT3_PIN);
int DHT4CHECK = DHT4.read11(DHT4_PIN);
if ((DHT1CHECK ==0)&&(DHT2CHECK ==0)&&(DHT3CHECK ==0)&&(DHT4CHECK ==0)) {
do {
////////Vertical
lcd.setCursor(0,0);
lcd.print("1.Humidity:");
lcd.print(DHT1.humidity,1);
lcd.print("%");
Blynk.virtualWrite(V1,DHT1.humidity);
lcd.setCursor(0,1);
lcd.print("2.Humidity:");
lcd.print(DHT2.humidity,1);
lcd.print("%");
Blynk.virtualWrite(V2,DHT2.humidity);
lcd.clear();
////////Horizontal
lcd.setCursor(0,0);
lcd.print("3.Humidity:");
lcd.print(DHT3.humidity,1);
lcd.print("%");
Blynk.virtualWrite(V3,DHT3.humidity);
lcd.setCursor(0,1);
lcd.print("4.Humidity:");
lcd.print(DHT4.humidity,1);
lcd.print("%");
Blynk.virtualWrite(V4,DHT4.humidity);
} while(lcd.print(""));
lcd.clear();
void WATERLVLSENSOR(){
int value = analogRead(A0);
lcd.print("Water status");
if (value <= 29) {
lcd.setCursor(3, 1);
lcd.print("Critical Level");
Blynk.notify("Critical Water Level!");
Blynk.virtualWrite(V6,"Critical Water Level");
else if (value > 30 && value < 250) {
lcd.print("Normal Level");
Blynk.virtualWrite(V6,"Normal Water Level");
else if (value > 250){
lcd.print("High!!");
Blynk.virtualWrite(V6,"High Water Level");
