Could you please help with the Blynk.sync?
I’d like to restore my parameters from the server on the ESP start.
I try to use Blynk.syncVirtual(V1) and even Blynk.syncAll() but nothing causes BLINK_WRITE to trigger.
For tests I have:
V1 - slider (0…1023) to change my LED light. It works when I slide this widget. But it does not restore LED light on start.
V2 - Numeric input (just for test)
V3 - Button to trigger sync manully
Code:
// #include <ESP8266WiFi.h>
#include <EasyBlynk8266.h>
#define ledPin 13
#define RelayPin 12
#define PIN_BUTTON 0
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
analogWrite(ledPin,pinValue);
BLYNK_WRITE(V2)
int pinValue = param.asInt(); // assigning incoming value from pin V2 to a variable
BLYNK_LOG2("V2 Slider value is: ", pinValue);
BLYNK_WRITE(V3)
Serial.println("SyncV2");
Blynk.syncVirtual(V2);
Serial.println("SyncAll");
Blynk.syncAll();
Serial.println("");
Serial.println("Starting..");
delay(2000);
Serial.println("set Pins..");
pinMode(ledPin, OUTPUT); // установка порта на выход для дублирования V1 на Pin 13 (green led)
analogWrite(ledPin, 1022);
pinMode(PIN_BUTTON, INPUT); // кнопка GPIO0
Serial.println("Starting EasyBlynk8266..");
EasyBlynk8266.begin();
Serial.println("EasyBlynk8266 completed.");
// Serial.println("Set V0..");
// Blynk.setProperty(V0, "offLabel", "Сохранить");
// Blynk.setProperty(V0, "onLabel", "Сохранено");
// while (Blynk.connect() == false) { }
Blynk.syncAll();
Serial.println("Delay 5 sec..");
delay(5000);
Blynk.syncAll();
Serial.println("Still no sync?");
BLYNK_CONNECTED() {
//get data stored in virtual pins from server
Serial.println("Sync..");
Blynk.syncAll();
EasyBlynk8266.run();
I have many debug Serial.print and expect that inside BLYNK_CONNECT a sync will call BLYNK_WRITE(V1) and I’ll see the debug output "V1 Slider value is: "
But:
[6946] Connecting to blynk-cloud.com:80`
[8077] Ready (ping: 53ms).
Sync..
Delay 5 sec..
Still no sync?
-= I press the button V3 =-
SyncV2
SyncAll
-= I change V2 =-
[32725] V2 Slider value is: 6
SyncV2
SyncAll
As you can see when I press the button V3 my sync is called explicitly. But the debug output “V3 Slider value is: 6” appears only when I change V2 in the app.
Looks like sync works neither on start (BLYNK_CONNECT) nor by the button.
Thanks in advance
