Hi friends. I want to using GCM push notification but it can not be working. I adding the gcm.properties file besides the server file and putting my gcm api key to gcm.properties but can’t be worked
thanks
thanks
Hello. You need to use default settings Blynk provide for the local server. You can’t use own credentials for GCM as this requires changes on the app side.
