Functions within functions
Hello everyone,
I’m pretty new to blynk and even newer in here so please bear with me. :slight_smile:
I want to create a function read sensor data, post it to the blynk app and then will call another function that should correct the devices that needs to be corrected.
I read somewhere that blynk app can only update a specific number of values to the app.
I want to first make sure it’s 100, if not then please let me know how many I can update?
And also I wanted to know if the values are send together when the function I call ends or does it send the data as it does the function?
Thank you in advance for all the answers.
I’m not really sure what you want to achieve here, so you might want to explain a bit better about your project (if you can of course). The Blynk app can handle a lot of updates because of the small foot print, but you should consider setting up a local server if you want to really send lots of data for the performance and to avoid flood issues. With a Local server you have much more control over that sort of things.
There is a limit to the number of updates per second (100 to 1000 I think) but no overall limit so there are very few projects you wouldn’t be able to run via Blynk.
It would really depend what your function does but generally I would say it is the latter.
you can update as many as you want (practically) :wink:
Also each “value” can be an array - consist of multiple values.
Ok great thank you. good to know. :slight_smile:
