BLYNK
'FunctionName' was not declared in this scope within Blynk menu
I’m getting a really annoying message from Arduino IDE. What is strange in my case is that this error appears continuously without any criteria even if the function is already declared.
Details :
• esp8266 + WIFI.
• Windows 10 x64
• Blynk server
• Blynk_Release_v0.6.1
My sketch code is down here:
#include <Ticker.h>
//#include <SimpleTimer.h>
char auth[] = "";
char ssidblynk[] = "*=* dP *=*";
char passblynk[] = "";
#define ECHOPIN 12  //Echo to pin D6
#define TRIGPIN 14   //Trig to pin D5
float duration,distance  ;
int Ep=0;
int functionCall = 0; // SimpleTimer used to stop and start a function
WidgetLCD lcd(V2);
WidgetLED ledcode(V0);
WidgetLED ledtype(V3);
WidgetLED ledep(V8);
Ticker blinker;
void changeState() {
  digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
int currentMenu;
int MenuIndexID;
BLYNK_WRITE(V1)
  MenuIndexID=param.asInt();
  if (currentMenu==0)
    timer.disable(functionCall);
    Serial.println("Regulation");
    lcd.clear(); //Use it to clear the LCD Widget
    lcd.print(0, 0, "Which one");
    if (MenuIndexID==1)
      ledcode.on();
      Serial.println("V2003");
      lcd.print(0, 0, "V2003");
      Blynk.setProperty(V1,"labels","Shear L","Shear U", "Shear T","Back");
      currentMenu=1;
      Blynk.virtualWrite(V1,1);
    else if (MenuIndexID==2)
      ledcode.on();
      Serial.println("E8");
      lcd.print(0, 0, "E8");
      Blynk.setProperty(V1,"labels","Shear L -Not yet-","Shear U -Not yet-","Shear L -Not yet-", "Back");
      currentMenu=2;
      Blynk.virtualWrite(V1,1); // Select the first menu item
    else if (MenuIndexID==3)
      ledcode.on();
      Serial.println("A97");
      lcd.print(0, 0, "A97");
      currentMenu=3;
    else {
  if (currentMenu==1)
    ledcode.on();
    if (MenuIndexID==1)
      ledtype.on();
      functionCall=1;
      digitalWrite(LED_BUILTIN,HIGH);
      Serial.println("Shear L In use");
      lcd.print(0, 0, "Shear: Forme L");
      timer.setTimeout(2000L,[](){lcd.print(0, 0, "Enter:  ");}); //
      functionCall=timer.setInterval(50, sendUptime);
      ledtype.on();
      functionCall=1;
      Serial.println("Shear U In use");
      ledtype.on();
      functionCall=1;
    else if (MenuIndexID==4) // Back
      Serial.println("Back");
      //lcd.clear(); //Use it to clear the LCD Widget
      lcd.print(0, 0, "Back");
      set_Menu0_labels();
    else {
  if (currentMenu==2)
    if (MenuIndexID==1)
      Serial.println("Shear L In use-Not yet-");
      lcd.print(0, 1, "Shear L In use-Not yet-");
      blinker.attach(0.5, changeState); //Use <strong>attach_ms</strong> if you need time in ms
      Serial.println("Shear U In use-Not yet-");
      lcd.print(0, 1, "Shear U In use-Not yet-");
      blinker.attach(1, changeState); //Use <strong>attach_ms</strong> if you need time in ms
      Serial.println("Shear T In use-Not yet-");
      lcd.print(0, 1, "Shear T In use-Not yet-");
      blinker.attach_ms(3, changeState); //Use <strong>attach_ms</strong> if you need time in ms
      timer.disable(functionCall); //Disable timer
      set_Menu0_labels();
  if (currentMenu==3)
    if (MenuIndexID==1)
      Serial.println("Shear L A97 In use-Not yet-");
      lcd.print(0, 1, "Shear L A97 In use-Not yet-");
      Serial.println("Shear U A97 In use-Not yet-");
      lcd.print(0, 1, "Shear U A97 In use-Not yet-");
      Serial.println("Shear T A97 In use-Not yet-");
      lcd.print(0, 1, "Shear T A97 In use-Not yet-");
      set_Menu0_labels();
  else {
void set_Menu0_labels()
  // Set the menu back to it's Menu 0 defaults
  // Doing this means that you only need to edit/define the Menu 0 labels on one location within the cdode
  Blynk.setProperty(V1,"labels","V2003","E8","A97");
  currentMenu=0;
  lcd.print(0, 0, "Regulation");
  Blynk.virtualWrite(V1,5); // Select the first menu item
  Blynk.virtualWrite(V5,0);
  Blynk.virtualWrite(V7,0);
  Blynk.virtualWrite(V4,0);
  EpShear=0;
  ledcode.off();
  ledtype.off();
  ledep.off();
BLYNK_WRITE(V6)
  EpShear = param.asInt(); // assigning incoming value from pin V1 to a variable
  lcd.print(0,1,EpShear);
  lcd.print(3,1,"Cm");
  Serial.println(EpShear);
BLYNK_CONNECTED()
  // This code runs when the ESP first connects to Blynk, or after a re-conection
  // Call the function to set the menu to it's "Menu 0" defaults
  set_Menu0_labels();
  pinMode(ECHOPIN, INPUT);
  pinMode(TRIGPIN, OUTPUT);
  Blynk.begin(auth, ssidblynk, passblynk);
void sendUptime() {
      if (EpShear!=0)
        ledep.on();
        lcd.print(0, 1, "Show:");
        digitalWrite(TRIGPIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGPIN, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHOPIN, HIGH);    //
  distance= (duration*0.035)/2+EpShear;      //
  double distanceTwoDic=distance; //
  double Error=distance*0.1/60; //
            Blynk.virtualWrite(V5, distanceTwoDic);   //
            Blynk.virtualWrite(V4, distanceTwoDic);
            Blynk.virtualWrite(V7, distanceTwoDic);
            Blynk.virtualWrite(V9,Error); //
            if (distance>=30)
            Serial.println(distanceTwoDic);
            lcd.print(0,0, "   !!!!!  ");
            Blynk.setProperty(V2,"color","#D3435C");
            Blynk.virtualWrite(V2,1);  //Update the pin
            lcd.print(0,0, "     BON      ");
              Blynk.setProperty(V2,"color","#23C48E");
Also, the error is attached down here:
C:\Users\mus76\Documents\Arduino\Menu_New_file_Backup\Menu_New_file_Backup.ino: In function 'void BlynkWidgetWrite1(BlynkReq&, const BlynkParam&)':
Menu_New_file_Backup:100:42: error: 'sendUptime' was not declared in this scope
Menu_New_file_Backup:111:42: error: 'sendUptime' was not declared in this scope
Menu_New_file_Backup:122:42: error: 'sendUptime' was not declared in this scope
Menu_New_file_Backup:131:24: error: 'set_Menu0_labels' was not declared in this scope
       set_Menu0_labels();
C:\Users\mus76\Documents\Arduino\Menu_New_file_Backup\Menu_New_file_Backup.ino: At global scope:
Menu_New_file_Backup:139:3: error: expected unqualified-id before 'if'
   if (currentMenu==2)
Multiple libraries were found for "Ticker.h"
 Used: C:\Users\mus76\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.1\libraries\Ticker
 Not used: C:\Program Files (x86)\Arduino\libraries\Ticker
exit status 1
Something weird here. If I remove the second if condition, the sketch compiles properly even if the function named ‘sendUptime’ that it keeps referring to, already exists in the first if condition.
Any suggestions?
@PeteKnight Isn’t in right place?
If it’s not, I’ll change it immediately as per you request.
Your problem is with one of the functions before the sendUptime function - in this case the BLYNK_WRITE(V1) function.
The issue is with un-matched curly brackets, and you can’t see this because of the horrendous way you’ve formatted your code and things like this:
Once you solved that, you need to declare the EpShear variable.
The Arduino IDE has the feature that if you select a closing bracket, it will highlight the corresponding opening bracket. When you select the last closing bracket of a function it should always highlight the initial opening bracket at the beginning of the function.
As I said before in your other topic…
thanks, @PeteKnight
I’ve already declared it, but some edits after the copy/paste affected it.
I didn’t notice that even when the code folding is enabled. It might happened after I added a closing bracket to the existing one that have been produced automatically by the Arduino IDE.
You are absolutely right. I should think twice about this horrendous sketch.
Thanks again, @PeteKnight
