FSR sensor blynk programming error
Hi, I am doing an IOT using blynk for my project.
My project is about the FSR sensor it will buzz when it reaches a big force.
now the problem is when I insert the original program with the blynk programming it doesn’t working the sensor is not detecting…
This is my IoT programming…(what should I do)?
#define BLYNK_TEMPLATE_ID "TMPL_tOo1Ip3"
#define BLYNK_DEVICE_NAME "SMAW"
#define BLYNK_AUTH_TOKEN "g0lCgk3RUziKGUW7y8y7tZ-IdEO6Rfxu"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
const int led1 = 14;
const int buzzer = 12;
int fsrPin = 25;
int fsrReading = 0;
int extension_count = 0;
char ssid[] = "iPhone 11";
char pass[] = "1234567745";
  pinMode(led1,OUTPUT);
  pinMode(buzzer,OUTPUT);
 // Serial.begin(115200);
  fsrReading = analogRead(fsrPin);
  Serial.print("Analog reading = ");
  Serial.print(fsrReading);
  int fsrReading_SENSED = digitalRead(fsrReading);
  if (fsrReading_SENSED < 10)
    digitalWrite(buzzer, LOW);
    digitalWrite(led1, LOW);
    Serial.println(" - No force");
    extension_count++;
    Blynk.virtualWrite(V1, " - No force");
  else if (fsrReading_SENSED < 100)
    Serial.println(" - Light force");
    extension_count++;
    Blynk.virtualWrite(V1, " - Light force");
  else if (fsrReading_SENSED < 630)
    Serial.println(" - Medium force");
    extension_count++;
    Blynk.virtualWrite(V1, " - Medium force");
    digitalWrite(led1, HIGH);
    digitalWrite(buzzer, HIGH);
    Serial.println(" - Big force");
    extension_count++;
    Blynk.virtualWrite(V1, " - Big force");
@Gajen Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
done
I’d start here…
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
