Hello all,
I started a new project for a weather station with several sensors connected to a nodemcu V3. If I upload the sketch the nodemcu is connected to the network and data is received as seen in the serial monitor. But when I look in the Blynk app, the device seems to be offline.
In the FritzBox I forwarded the nodemcu as seen in the screenshot below.
But still nothing appears to come online in the Blynk app. Searching the internet didn’t gave me the answer to my problem.
It is working on an other wifi network, so I think it is my own network causing the problem.
How can I get the nodemcu device online in the Blynk app? My experience level is very low and still in a learning curve.
My used sketch:
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#define BLYNK_TEMPLATE_ID “XXXXX”
#define BLYNK_DEVICE_NAME “XXXXXXXXX”
#define BLYNK_AUTH_TOKEN “XXXXXXX”
#include <DHT.h>
#include <Adafruit_BMP280.h>
char ssid[] = “XXXX”;
char pass[] = “XXXXXX!”;
#define DHTPIN D4 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
//float p = dht.readPressure();
// float r = dht.readRain();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
// Blynk.virtualWrite(V3, p);
// Blynk.virtualWrite(V2, r);
// Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, "blynk.cloud", 8080);
// Blynk.begin(auth, ssid, pass, IPAddress(192,168,178,100), 8080);
dht.begin();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
// Read temperature as Celsius (the default)
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
// Compute heat index in Fahrenheit (the default)
float hif = dht.computeHeatIndex(f, h);
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.print(F("°C "));
Serial.print(f);
Serial.print(F("°F Heat index: "));
Serial.print(hic);
Serial.print(hif);
Serial.println(F("°F"));
