Four push button
Good morning all,
I have a problem in my code. I want to control 4 relays with four push button and / or blynk application.
I only have button 1 which reacts quickly with aplication.
Do you have any idea how to fix this problem
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxxxxxxxx";
// Set your LED and physical button pins here
const int relais1 = 17;
const int btn1 = 25;
const int led1 = 33;
const int relais2 = 5;
const int btn2 = 26;
const int led2 = 32;
const int relais3 = 18;
const int btn3 = 27;
const int led3 = 35;
const int relais4 = 19;
const int btn4 = 14;
const int led4 = 34;
// one wire temperature
#define ONE_WIRE_BUS 23
int deviceCount = 3;
float tempC;
void checkPhysicalButton1();
void checkPhysicalButton2();
void checkPhysicalButton3();
void checkPhysicalButton4();
void temperature();
int relais1Sate = LOW;
int btn1State = HIGH;
int led1State = LOW;
int relais2Sate = LOW;
int btn2State = HIGH;
int led2State = LOW;
int relais3Sate = LOW;
int btn3State = HIGH;
int led3State = LOW;
int relais4Sate = LOW;
int btn4State = HIGH;
int led4State = LOW;
int lcd_position[] = {16, 30, 44}; // position temperature sur l'écran
BLYNK_WRITE(V1) {
  relais1Sate = param.asInt();
  digitalWrite(relais1, relais1Sate);
  led1State = param.asInt();
  digitalWrite(led1, led1State);
BLYNK_WRITE(V2) {
  relais2Sate = param.asInt();
  digitalWrite(relais2, relais2Sate);
  led2State = param.asInt();
  digitalWrite(led2, led2State);
BLYNK_WRITE(V3) {
  relais3Sate = param.asInt();
  digitalWrite(relais3, relais3Sate);
  led3State = param.asInt();
  digitalWrite(led3, led3State);
BLYNK_WRITE(V4) {
  relais4Sate = param.asInt();
  digitalWrite(relais4, relais4Sate);
  led4State = param.asInt();
  digitalWrite(led4, led4State);
void temperature()
  display.clearDisplay();
  display.display();
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(0, 0);
  display.println("---------------------");
  display.setCursor(0, 6);
  display.print("|    Temperature    |");
  display.setCursor(0, 12);
  display.setCursor(0, 16); // position 0
  display.println(" Interieur  |");
  display.print("---------------------");
  display.display();
  display.setCursor(0, 30); // position 1
  display.println(" Exterrieur |");
  display.display();
  display.setCursor(0, 44); // position 2
  display.println(" Eau        |");
  display.display();
  // Send command to all the sensors for temperature conversion
  // Display temperature from each sensor
  for (int i = 0;  i < deviceCount;  i++)
    tempC = sensors.getTempCByIndex(i);
    Blynk.virtualWrite(i + 21, tempC);
    display.setCursor(80, lcd_position[i]);
    display.print(tempC);
    display.display();
  if (digitalRead(btn1) == LOW) {
    if (btn1State != LOW) {
      // Toggle LED state
      relais1Sate = !relais1Sate;
      led1State = !led1State;
      // Update Button Widget
      Blynk.virtualWrite(V1, relais1Sate);
      Blynk.virtualWrite(V1, led1State);
    btn1State = LOW;
    btn1State = HIGH;
  if (digitalRead(btn2) == LOW) {
    if (btn2State != LOW) {
      // Toggle LED state
      relais2Sate = !relais2Sate;
      led2State = !led2State;
      Blynk.virtualWrite(V2, relais1Sate);
      Blynk.virtualWrite(V2, led1State);
    btn2State = LOW;
    btn2State = HIGH;
  if (digitalRead(btn3) == LOW) {
    if (btn3State != LOW) {
      // Toggle LED state
      relais3Sate = !relais3Sate;
      led3State = !led3State;
      Blynk.virtualWrite(V3, relais1Sate);
      Blynk.virtualWrite(V3, led1State);
    btn3State = LOW;
    btn3State = HIGH;
  if (digitalRead(btn4) == LOW) {
    if (btn4State != LOW) {
      // Toggle LED state
      relais4Sate = !relais4Sate;
      led4State = !led4State;
      Blynk.virtualWrite(V4, relais1Sate);
      Blynk.virtualWrite(V4, led1State);
    btn4State = LOW;
    btn4State = HIGH;
  sensors.begin();  // debut de la librairie capteur de température
  WiFi.begin(ssid, pass);
  //timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
  Blynk.config(auth);
  pinMode(relais1, OUTPUT);
  pinMode(btn1, INPUT_PULLUP);
  pinMode(led1, OUTPUT);
  pinMode(relais2, OUTPUT);
  pinMode(btn2, INPUT_PULLUP);
  pinMode(led2, OUTPUT);
  pinMode(relais3, OUTPUT);
  pinMode(btn3, INPUT_PULLUP);
  pinMode(led3, OUTPUT);
  pinMode(relais4, OUTPUT);
  pinMode(btn4, INPUT_PULLUP);
  pinMode(led4, OUTPUT);
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for (;;); // Don't proceed, loop forever
  // Clear the buffer
  display.display();
  timer.setInterval(100L, checkPhysicalButton1);
  timer.setInterval(200L, checkPhysicalButton2);
  timer.setInterval(300L, checkPhysicalButton3);
  timer.setInterval(400L, checkPhysicalButton4);
  timer.setInterval(10000L, temperature);
  // to avoid delay() function!
Button 1 is being checked every 100 milliseconds,
Button 2 is being checked every 200 milliseconds,
Button 3 is being checked every 300 milliseconds,
Button 4 is being checked every 400 milliseconds
It’s not surprising that button 4 is four times less responsible than button 1.
The sensible solution is to have one timer which calls a function that checks each of the 4 buttons in turn.
Or, attach interrupts to the four buttons so that you don’t have to keep scanning them.
is it better ??
#include <WiFi.h>
#include <Wire.h>
char auth[] = "xxxxxxxxxxxx";
char ssid[] = "xxxxxxxxx";
char pass[] = "xxxxxxxx";
float tempC;
void temperature();
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
BLYNK_WRITE(V4) {
void temperature()
  display.display();
  display.display();
  display.display();
  display.display();
    display.display();
void checkPhysicalButtonAll()
      // Toggle LED state
    btn1State = LOW;
    btn1State = HIGH;
      // Toggle LED state
    btn2State = LOW;
    btn2State = HIGH;
      // Toggle LED state
    btn3State = LOW;
    btn3State = HIGH;
      // Toggle LED state
    btn4State = LOW;
    btn4State = HIGH;
  Blynk.config(auth);
  // Clear the buffer
  display.display();
  timer.setInterval(100L,checkPhysicalButtonAll);
Your code doesn’t make any sense to me.
could you detail this part a little more so that I understand better
One function which contains all of the code that is currently in your four functions.
Also, there’s no need for the debounce code when you’re scanning the buttons with a timer every 100ms.
You would need the debounce code if you were using interrupts though, which would be my preferred approach.
A function for my four buttons, is that correct?
#include <WiFi.h>
#include <Wire.h>
char auth[] = "xxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxxxx";
float tempC;
void temperature();
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
BLYNK_WRITE(V4) {
void temperature()
  display.display();
  display.display();
  display.display();
  display.display();
    display.display();
      // Toggle LED state
    btn1State = LOW;
    btn1State = HIGH;
      // Toggle LED state
    btn2State = LOW;
    btn2State = HIGH;
      // Toggle LED state
    btn3State = LOW;
    btn3State = HIGH;
      // Toggle LED state
    btn4State = LOW;
    btn4State = HIGH;
  Blynk.config(auth);
  // Clear the buffer
  display.display();
  timer.setInterval(100L,checkPhysicalButton1);
Yes.
However, your function has a very misleading name, still has the unnecessary debounce code for each button, and you are still pre-declaring the four functions…
Pre-declaring functions is unnecessary, and in my opinion makes the code less readable.
@PeteKnight thank you very much for your help
