Flood error - help identify where
got blynk flood error after a day this was connected.
anyone who can see where it goes wrong?
  ITEAD Sonoff S31 and S20 for the Blynk app.
#include <TimeLib.h>
#include <WidgetRTC.h>
int buttonPin = 0;              // Sonoff On/Off button
int relayPin = 12;              // Sonoff relay
int ledPin = 13;                // Sonoff green LED - always on
int relayStatus = 0;
int buttonState = LOW;          // variable for reading the pushbutton status
int lastButtonState = HIGH;     // previous state of the button
int relayState = LOW;
int ledState = LOW;
long lastTime = 0;             // the last time the output pin was toggled
long debounce = 200;           // the debounce time, increase if the output flickers
WidgetRTC rtc;
char Date[16];
char Time[16];
int manual=0;
long startsecondswd;            // weekday start time in seconds
long stopsecondswd;             // weekday stop  time in seconds
long nowseconds;                // time now in seconds
// V1 is virtualbutton
// v2 test button for timer
// V10 is virtualLed
// V11 is Dateprint
// V12 is wifi signal
// v13 auto-manual
// V14 is virtual time-date picker
const char* ssid     = "";
const char* password = "";
//char auth[] = "blynk authorization"; // Sonoff S31 "4M(3M SPIFFS)"
char auth[] = ""; // Sonoff S20 "1M(512k SPIFFS)"
WidgetLED led1(V10); // Widget Relay LED
BLYNK_WRITE(V1) { // Widget relay button
  relayStatus = param.asInt();
  if (relayStatus == 1) {
    relayState = HIGH;
  else {
    relayState = LOW;
} // end - BLYNK_WRITE(V1)
  WiFi.mode(WIFI_STA);
  Blynk.begin(auth, ssid, password);
    //Wait until connected
    Serial.print("trying to connect waiting");
  rtc.begin();
  pinMode(buttonPin, INPUT);  // on/off button
  pinMode(relayPin, OUTPUT);  // relay
  pinMode(ledPin, OUTPUT);    // greenled
  digitalWrite(ledPin, LOW);  // always on
  //Setting automaticmode to on(1)
  Blynk.virtualWrite(V13, 0);
  timer.setInterval(100000L, sendWifi);
  timer.setInterval(60000L, syncRelay);
  timer.setInterval(10000,showCurrentTime);
} // end - setup()
BLYNK_WRITE(V13)
  if (param.asInt()==1)
    manual=1;
    manual=0;
BLYNK_WRITE(V14)//datepicker
    if (manual==1)
      sprintf(Date, "%02d/%02d/%04d",  day(), month(), year());
      TimeInputParam t(param);
      Serial.println(Time);
      Serial.println(Date);
      int dayadjustment = -1;
      if(weekday() == 1){
        dayadjustment =  6; // needed for Sunday, Time library is day 1 and Blynk is day 7
      if(t.isWeekdaySelected(weekday() + dayadjustment)){ //Time library starts week on Sunday, Blynk on Monday
      nowseconds = ((hour() * 3600) + (minute() * 60) + second());
      startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
      Serial.println(startsecondswd);  // used for debugging
      if(nowseconds >= startsecondswd){
        if(nowseconds <= startsecondswd + 90){    // 90s on 60s timer ensures 1 trigger command is sent
          Blynk.virtualWrite(V1, 1);
          // code here to switch the relay ON
      stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
      Serial.println(stopsecondswd);  // used for debugging
      if(nowseconds >= stopsecondswd){
        Blynk.virtualWrite(V1, 0);
        if(nowseconds <= stopsecondswd + 90){   // 90s on 60s timer ensures 1 trigger command is sent
          // code here to switch the relay OFF
      else{
       // nothing to do today, check again in 30 SECONDS time
void pushButton() {
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH && lastButtonState == LOW && millis() - lastTime > debounce) {
    if (relayState == HIGH) {
      relayState = LOW;
    else {
      relayState = HIGH;
    lastTime = millis();
  digitalWrite(relayPin, relayState); // Relay open/close - digital pin 12
  lastButtonState = buttonState;
} //end - pushButton()
void ledStatus() { // Widget LED - relay status
  ledState = digitalRead(relayPin);
  if (ledState == HIGH)
    led1.on();
    led1.off();
} // end - ledStatus()
void syncRelay()
  Blynk.syncAll();
  Serial.println("sync relay");
void showCurrentTime()
  String CurrentDate = String(day()) + '-' + monthShortStr(month()) + '-' + year();
  String CurrentTime = String(hour()) + ':' + minute() + ':' + second();
  String formattedDate = CurrentDate + String(" | ") + CurrentTime;
  Blynk.virtualWrite(V11,formattedDate);
void sendWifi()
  Blynk.virtualWrite(12, map(WiFi.RSSI(), -105, -40, 0, 100) );
  pushButton();
  ledStatus();
This code is being called every time the void loop() executes, which could be hundreds if not thousands of times per second - depending on the clock speed of your processor and how long the code that’s being called takes to execute.
led1 is an LED widget connected to V10.
Because Of the way that you’ve used the else statement in this function, you’re going to update the LED widget with either “on” or “off”, EVERY SINGLE TIME THE VOID LOOP RUNS.
I think that’s enough to flood the server!
thx, it must be it, will look into it
