I want to build a circuit where I can switch LEDs with different blink rhythms in the Blynk app. I want to be able to switch the LEDs on and off via the app. It would be perfect if I could control the different blink rythms via the app, but it would also work that the blink rythms are changed via a button press.
I am still quite inexperienced in coding and soldering, so I would appreciate any help.
I use an ESP8266 as controller.
Thanks a lot
Iād recommend using the search facility within this forum.
