Hello friends.
Can anyone please help me with my project?
I have an issue with buzzer2 and the fire sensor.
The buzzer2 is not working at all, even when tested in the replacement of buzzer in the code, is not the module, i tested and it works fine.
The flame sensor its working properly, but the problem is with my code, i can make it light de led or turn on the buzzer or buzzer2.
Here’s my code.
Thanks.
//Definição dos templates gerados no site do Blynk
#define BLYNK_TEMPLATE_ID "TMPL2_9ioaApf"
#define BLYNK_TEMPLATE_NAME "ESP32 Home Automation"
#define BLYNK_AUTH_TOKEN "DiJTp_VJhdGhuger9iKs-V5HOg_ftifn"
//Inclusão das bibliotecas utilizadas
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
#include <Servo.h>
//Impressão das informações na serial, pode ser retirado
//Definição da luminosidade do sensor LDR
#define LUMINOSIDADE 500
//Inicia o processo de autenticação do Blynk
// Login e Senha da internet
char ssid[] = "Brigadeiro_2G";
char pass[] = "4890909090";
//Definindo os pinos conectados
#define LED_1 27
#define LED_2 26
#define LED_3 25
#define LED_4 33
#define SERVO_PIN 13
#define DHT_PIN 19
#define DHTTYPE DHT11
#define LDR_SENSOR 35
#define LDR_LED 15
#define PIR_PIN 4
#define PIR_LED1 18
#define PIR_LED2 21
#define BUZZER 22
#define BUZZER2 2
#define FLAME 32
//Estado incial dos leds
int STATE_LED_1 = 0;
int STATE_LED_2 = 0;
int STATE_LED_3 = 0;
int STATE_LED_4 = 0;
//int PIR_LED1 = 0;
//int PIR_LED2 = 0;
//Pins definidos no site do Blynk
#define VPIN_BUTTON_1 V0
#define VPIN_BUTTON_2 V1
#define VPIN_BUTTON_3 V2
#define VPIN_BUTTON_4 V3
#define VPIN_TEMPERATURE V4
#define VPIN_HUMIDITY V5
#define VPIN_BUTTON_5 V6
#define VPIN_BUTTON_6 V8
#define VPIN_BUTTON_7 V9
//Nomeia e inicia o sensor de temperatura
DHT dht(DHT_PIN, DHTTYPE);
//Nomeia e inicia o Servo
Servo servo;
bool botaopir = 0;
int botaochama = 0;
bool fireDetected = false;
//Função de conexão do Blynk
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
Blynk.syncVirtual(VPIN_BUTTON_3);
Blynk.syncVirtual(VPIN_BUTTON_4);
Blynk.syncVirtual(VPIN_BUTTON_5);
Blynk.syncVirtual(VPIN_BUTTON_6);
Blynk.syncVirtual(VPIN_BUTTON_7);
//Função que altera as saídas de acordo com os botões virtuais
BLYNK_WRITE(VPIN_BUTTON_1) {
STATE_LED_1 = param.asInt();
digitalWrite(LED_1, STATE_LED_1);
Serial.print("Led1 State = "); Serial.println(STATE_LED_1);
BLYNK_WRITE(VPIN_BUTTON_2) {
STATE_LED_2 = param.asInt();
digitalWrite(LED_2, STATE_LED_2);
Serial.print("Led2 State = "); Serial.println(STATE_LED_2);
BLYNK_WRITE(VPIN_BUTTON_3) {
STATE_LED_3 = param.asInt();
digitalWrite(LED_3, STATE_LED_3);
Serial.print("Led3 State = "); Serial.println(STATE_LED_3);
BLYNK_WRITE(VPIN_BUTTON_4) {
STATE_LED_4 = param.asInt();
digitalWrite(LED_4, STATE_LED_4);
Serial.print("Led4 State = "); Serial.println(STATE_LED_4);
BLYNK_WRITE(VPIN_BUTTON_5) {
int pinValue = param.asInt();
if (pinValue == 1) {
servo.write(0);
}else
servo.write(90);
BLYNK_WRITE(VPIN_BUTTON_6) {
botaopir = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_7) {
int botaochama = param.asInt();
//Função Setup
void setup(){
//Definindo os leds como pinos de saída
pinMode(LED_1, OUTPUT);
pinMode(LED_2, OUTPUT);
pinMode(LED_3, OUTPUT);
pinMode(LED_4, OUTPUT);
pinMode(LDR_LED, OUTPUT);
pinMode(PIR_LED1, OUTPUT);
pinMode(PIR_LED2, OUTPUT);
pinMode(BUZZER, OUTPUT);
pinMode(BUZZER2, OUTPUT);
pinMode(LDR_SENSOR, INPUT);
pinMode(PIR_PIN, INPUT);
pinMode(FLAME, INPUT);
//Estado inicial dos leds
digitalWrite(LED_1, HIGH);
digitalWrite(LED_2, HIGH);
digitalWrite(LED_3, HIGH);
digitalWrite(LED_4, HIGH);
//Inicia o sensor de temperatura
dht.begin();
//Inicia a autenticação do Blynk
//Timer do sensor de temperatura
timer.setInterval(500, Send_Sensor);
timer.setInterval(500, presenca);
//Define o servo no pino 13 e coloca na posição 0
servo.attach(13);
servo.write(90);
//Função loop
sensorFogo();
int valorSensor = analogRead(LDR_SENSOR);
Serial.println(valorSensor);
delay(2000);
if (valorSensor < LUMINOSIDADE)
digitalWrite(LDR_LED, HIGH);
}else
digitalWrite(LDR_LED, LOW);
/* void sensorFogo() {
bool chama = digitalRead(FLAME);
Serial.println(FLAME);
if (chama == 0) {
digitalWrite(BUZZER2, LOW);
} else if (chama == 1) {
digitalWrite(BUZZER2, HIGH);
void sensorFogo ()
Serial.println(chama);
if (botaochama == 1)
if (chama == 0)
digitalWrite(PIR_LED1, HIGH);
} else if (chama == LOW)
digitalWrite(PIR_LED1, LOW);
} else if (botaochama == 1)
//Função do Sensor de Temperatura
void Send_Sensor()
float h = dht.readHumidity();
//Serial.print("Temperature - "); Serial.print(t); Serial.println("°C");
//Serial.print("Humidity - "); Serial.print(h); Serial.println("%");
//delay(5000);
void presenca ()
bool pir = digitalRead(23);
if (botaopir == 1)
//Serial.println("Monitoramento de movimento ligado!!!");
if (pir == 1)
digitalWrite(PIR_LED2, HIGH);
digitalWrite(BUZZER, HIGH);
} else if (pir == 0)
digitalWrite(PIR_LED2, LOW);
digitalWrite(BUZZER, LOW);
} else if (botaopir == 0)
//Serial.println("Monitoramento de movimento desligado!!!");
//Função de Controle dos leds no Blynk
void ControlLed(int number, int led_pin, int &status, int virtual_pin){
delay(200);
status = !status;
digitalWrite(led_pin, status);
delay(50);
Blynk.virtualWrite(virtual_pin, status); //update button state
Serial.print("Led"+String(number)+" State = "); Serial.println(status);
