Can Blynk 2.0 modify the reconnection time?
when the wifi is disconnected, keep running in the loop until the specified time is reached before reconnecting.
If you write your sketch using Blynk.config and Blynk.begin, and manually manage your WiFi connection, then itβs possible - just as it was with Blynk Legacy.
Hello
Try this
void connection_check(){
if(Blynk.connected() == true){ // if blynk is connected
digitalWrite(blynk_connect_pin, HIGH); // connected led turned on
digitalWrite(blynk_disconnect_pin, LOW); // disconnected led turned off
Serial.println("Blynk Connected");} //
else if(Blynk.connected() == false){ // if blynk is not connected
Serial.println("Reconnecting..."); //
digitalWrite(blynk_connect_pin, LOW); // connected led turned off
digitalWrite(blynk_disconnect_pin, HIGH); // disconnected led turned on
@Huzefamaz1 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
