As the number of projects and their complexity increases, it becomes useful to be able to put on the blynk app some info on the various widgets.
I am thinking of a very simple solution (from what I can conceive ! ) for the developers. It would be an info button of small size, that would pop up a window of the size of the device with the info text. So no connections with the hardware.
In the same way as the info texts for the various widgets.
In order to insert large texts as in the widget info, there will be some need to be able to transmit a text written on a computer with a decent keyboard.
So here maybe there is some additional work.
That would be really useful, especially when you transmit a blynk application to another user.
Thanks for the good work !
Jacques
