FastLed with push button
Good morning all
I give my code because I would like to replace my basic LEDs, with programable LEDs (WS2811) using the FASTLED library
I have 4 WS2811 leds, and 4 push button, I would like my LEDs to change color each time I press the push button or the button widget
I did my first test on if (btn1State! = LOW) and BLYNK_WRITE (V1) but nothing works. Do you have any idea why?
#define BLYNK_TEMPLATE_ID "XXXXXX"
#define BLYNK_DEVICE_NAME "XXXXX"
#define BLYNK_FIRMWARE_VERSION        "0.1.0"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
#include "BlynkEdgent.h"
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#include <FastLED.h>
#define NUM_LEDS 4
#define DATA_PIN 13
CRGB leds[NUM_LEDS];
const int relais1 = 14;
const int btn1 = 27;
const int ledV1 = 5;
const int ledR1 = 2;
const int relais2 = 32;
const int btn2 = 26;
const int ledV2 = 18;
const int ledR2 = 4;
const int relais3 = 15;
const int btn3 = 25;
const int ledV3 = 19;
const int ledR3 = 16;
const int relais4 = 12;
const int btn4 = 33;
const int ledV4 = 17;
const int ledR4 = 13;
// one wire temperature
#define ONE_WIRE_BUS 23
int deviceCount = 3;
float tempC;
void temperature();
int relais1Sate = LOW;
int btn1State = HIGH;
int relais2Sate = LOW;
int btn2State = HIGH;
int relais3Sate = LOW;
int btn3State = HIGH;
int relais4Sate = LOW;
int btn4State = HIGH;
int brightness = 50;
int lcd_position[] = {16, 30, 44}; // position temperature sur l'écran
BLYNK_WRITE(V1) {
  relais1Sate = param.asInt();
  Serial.print("Widget Button V1 changed. Writing ");
  Serial.print(relais1Sate);
  Serial.print(" to Relay 1 and LED V1, and ");
  Serial.print(!relais1Sate);
  Serial.println(" to LED R1 ...");
  digitalWrite(relais1, !relais1Sate);
  leds[0] = CRGB::Red, !relais1Sate;
  leds[0] = CRGB::Blue, relais1Sate;
  FastLED.show();
BLYNK_WRITE(V2) {
  relais2Sate = param.asInt();
  digitalWrite(relais2, !relais2Sate);
  digitalWrite(ledV2, !relais2Sate);
  digitalWrite(ledR2, relais2Sate);
BLYNK_WRITE(V3) {
  relais3Sate = param.asInt();
  digitalWrite(relais3, !relais3Sate);
  digitalWrite(ledV3, !relais3Sate);
  digitalWrite(ledR3, relais3Sate);
BLYNK_WRITE(V4) {
  relais4Sate = param.asInt();
  digitalWrite(relais4, !relais4Sate);
  digitalWrite(ledV4, !relais4Sate);
  digitalWrite(ledR4, relais4Sate);
void temperature()
  display.clearDisplay();
  display.display();
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(0, 0);
  display.println("---------------------");
  display.setCursor(0, 6);
  display.print("|    Temperature    |");
  display.setCursor(0, 12);
  display.setCursor(0, 16); // position 0
  display.println(" Interieur  |");
  display.print("---------------------");
  display.display();
  display.setCursor(0, 30); // position 1
  display.println(" Exterrieur |");
  display.display();
  display.setCursor(0, 44); // position 2
  display.println(" Eau        |");
  display.display();
  // Send command to all the sensors for temperature conversion
  // Display temperature from each sensor
  for (int i = 0;  i < deviceCount;  i++)
    tempC = sensors.getTempCByIndex(i);
    Blynk.virtualWrite(i + 21, tempC);
    display.setCursor(80, lcd_position[i]);
    display.print(tempC);
    display.display();
void checkPhysicalButton1()
  if (digitalRead(btn1) == LOW)
    Serial.print("Location A, btn1 = ");
    Serial.print(digitalRead(btn1));
    Serial.print(" btn1State = ");
    Serial.println(btn1State);
    if (btn1State != LOW)
      Serial.print("Location B, btn1 = ");
      Serial.print(btn1);
      Serial.print(", btn1State = ");
      // Toggle LED state
      relais1Sate = !relais1Sate;
      Serial.print("Location C, writing ");
      Serial.println(" to Relay 1 ...");
      Serial.print("Location D, writing ");
      Serial.print(" to LED V1 and ");
      FastLED.show();
      // Update Button Widget
      Serial.print("Location E, writing ");
      Serial.println(" to Button Widget on pin V1 ...");
      Blynk.virtualWrite(V1, relais1Sate);
      btn1State = LOW;
    btn1State = HIGH;
  if (digitalRead(btn2) == LOW)
    if (btn2State != LOW)
      // Toggle LED state
      relais2Sate = !relais2Sate;
      Blynk.virtualWrite(V2, relais2Sate);
      btn2State = LOW;
    btn2State = HIGH;
  if (digitalRead(btn3) == LOW)
    if (btn3State != LOW)
      // Toggle LED state
      relais3Sate = !relais3Sate;
      Blynk.virtualWrite(V3, relais3Sate);
      btn3State = LOW;
    btn3State = HIGH;
  if (digitalRead(btn4) == LOW)
    if (btn4State != LOW)
      // Toggle LED state
      relais4Sate = !relais4Sate;
      Blynk.virtualWrite(V4, relais4Sate);
      btn4State = LOW;
    btn4State = HIGH;
BLYNK_CONNECTED()
  Blynk.syncVirtual(V1);
  Blynk.syncVirtual(V2);
  Blynk.syncVirtual(V3);
  Blynk.syncVirtual(V4);
void checkPhysicalButton1();
  delay(100);
  BlynkEdgent.begin();
  FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
  sensors.begin();  // debut de la librairie capteur de température
  pinMode(relais1, OUTPUT);
  pinMode(btn1, INPUT_PULLUP);
  digitalWrite(relais1, relais1Sate);
  pinMode(ledV1, OUTPUT);
  pinMode(ledR1, OUTPUT);
  pinMode(relais2, OUTPUT);
  pinMode(btn2, INPUT_PULLUP);
  digitalWrite(relais2, relais2Sate);
  pinMode(ledV2, OUTPUT);
  pinMode(ledR2, OUTPUT);
  pinMode(relais3, OUTPUT);
  pinMode(btn3, INPUT_PULLUP);
  digitalWrite(relais3, relais3Sate);
  pinMode(ledV3, OUTPUT);
  pinMode(ledR3, OUTPUT);
  pinMode(relais4, OUTPUT);
  pinMode(btn4, INPUT_PULLUP);
  digitalWrite(relais4, relais4Sate);
  pinMode(ledV4, OUTPUT);
  pinMode(ledR4, OUTPUT);
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for (;;); // Don't proceed, loop forever
  // Clear the buffer
  display.display();
  timer.setInterval(100L, checkPhysicalButton1);
  timer.setInterval(10000L, temperature);
  BlynkEdgent.run();
