Failed to disable echo (error) 010517
Hello there… im trying to create project with arduino uno + blynk + esp8266… i have flashed esp8266 with ai-thinker-0.9.5.2-9600 bin… but when i run the coding im still hving the failed to disable echo problem… how to solve it?
[UPD: “Failed to disable echo” will most probably be reported as “ESP is not responding” now]
In this forum alone, there are many reasons for that error, and many fixes depending on the reasons… you simply need to do some…
Try searching for the error msg, document the various solutions and try them one by one.
