Failed to connect WiFi
I want to make a project with the ESP8266 and Arduino. Now i tried to get Connections with the Blynk app to the Module by using this Code:
    Social networks:            http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example shows how to use ESP8266 Shield (with AT commands)
  to connect your project to Blynk.
  WARNING!
    It's rather tricky to get it working, please read this article:
    https://github.com/blynkkk/blynk-library/wiki/ESP8266-with-AT-firmware
#include <ESP8266_Lib.h>
char auth[] = "87edecee065d471681b528250161f607";
char ssid[] = "Wlan";
char pass[] = "12345678";
//#define EspSerial Serial1
SoftwareSerial EspSerial(10, 11); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  // Set ESP8266 baud rate
I want to use an Andoid hotspot called “Wlan” to connect to the Server. But i always get this error in the Serial Monitor:
[19]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.8 on Arduino Uno
[603] Connecting to Wlan
[3816] AT version:0.40.0.0(Aug  8 2015 14:45:58)
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
OK
[14007] Failed to connect WiFi
Proper formatting is triple backticks fore and aft of code placement:
Blynk - FTFC
Have you tried searching this forum for your error msg?
https://community.blynk.cc/search?q=Failed%20to%20connect%20WiFi
Have you confirmed proper hookup and dedicated power for your ESP?
http://help.blynk.cc/how-to-connect-different-hardware-with-blynk/arduino/esp8266-with-at-firmware
Tanks for the answer.
Yes i was looking in the Forum there and didn’t find anything.
And i already tried some AT-commands using this code:
SoftwareSerial mySerial(10, 11);  //RX,TX
//  Arduino pin 2 (RX) to ESP8266 TX
//  Arduino pin 3 to voltage divider then to ESP8266 RX
//  Connect GND from the Arduiono to GND on the ESP8266
//  Pull ESP8266 CH_PD HIGH
// When a command is entered in to the serial monitor on the computer
// the Arduino will relay it to the ESP8266
int LEDPIN = 13;
    pinMode(LEDPIN, OUTPUT);
    Serial.begin(9600);     // communication with the host computer
    //while (!Serial)   { ; }
    // Start the software serial for communication with the ESP8266
    mySerial.begin(9600);
    Serial.println("");
    Serial.println("Remember to to set Both NL & CR in the serial monitor.");
    Serial.println("Ready");
    Serial.println("");
    // listen for communication from the ESP8266 and then write it to the serial monitor
    if ( mySerial.available() )   {  Serial.write( mySerial.read() );  }
    // listen for user input and send it to the ESP8266
    if ( Serial.available() )       {  mySerial.write( Serial.read() );  }
And it worked. With this Sketch above i also could connect to the hotspot.
I solved the Problem i tried using my personal mobile phone as a Hotspot, and it worked. i think the problem was that the internet connection from the phone i used before was somehow blocked, for devices like the Arduino, by the company i am working.
