Expandable graph
I’ve got an idea for graph widget expansion. First of all, graph in current form is taking 1/3rd of a screen, and if you want to put sensors on the graph with different scaling, the graph becomes unreadable (e.g. when you put DHT22 temperature and humidity on one graph, the value of humidity is much bigger than temperature, and scaling of the vertical axe is getting so big, that you can’t really determine anything from the temperature).
My idea is to put expandable graph widget. So, if we have for example widget for the temperature, we could touch it, and it would take us to the beautiful-fullscreen graph with the value from this widget.
This graph could also be clickable with adjustable timescale (like it’s now) and also pressing on the line on the line at the graph could show the value at the desired point.
